A flash loader writes to the flash chip directly. Two ways to do it - connect to the spi signals on the board or unsolder the flash chip and put it in a socket on the flash loader. Either is very likely to give you a dead piece of PCB. The vocore pinout spacing makes it very easy to short things together and unsoldering/resoldering the chip without expensive equipment takes extreme skill. Just the fact that you need to ask means you don't want to try this. I have put a flash loader together with an Arduino (a USBASP is really just another type of Arduino) before and it works but this is very slow writing the system image takes a few hours. I used a breakout board to get to the spi signals safely.
It is almost impossible to kill uboot (unless you use a flash loader), if you can get to a command prompt at all, just type reboot and you'll get the u-boot menu. Vonger did something with his GD32 USB/UART that doesn't let you see the uboot menu on power on so the method you used is probably the best way to get to the menu if you can't get to a command prompt.
If you want to use Ethernet, there is a recovery web page in u-boot, plug your VoCore2 directly into your computer with a Ethernet cable, set up the network config on your computer for static addressing with an IP of 192.168.1.2. From the u-boot menu use option 8, then point a web browser at 192.168.1.123
I think the easiest for you is to put an image on a USB drive and name it root_uImage plug it into the USB connector and use option 5 on the uboot menu. The file has to be on the first partition of the flash drive and it has to be formatted vfat. Most (all?) USB drives smaller than 32G have one partition and it is formatted vfat so just use a cheap one and you'll be ok.
To repeat my self without all the fluff you need:
1. USB drive with first partition formatted vfat
2. The image must be on the first partition and must be named root_uImage
3. Use option 5 from the uboot menu
The process will look like this:
[ 217.740000] reboot: Restarting system
Software System Reset Occurred
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
RESET MT7628 PHY!!!!!!
Please choose the operation:
gpio trigger enabled
GPIO 46 is low
23
You chose 5
0
5: System Load Linux then write to Flash via USB Storage.
(Re)start USB...
USB0: *********ehci_hcd_init**********
Mediatek/Ralink USB EHCI host init hccr b01c0000 and hcor b01c0010 hc_length 16
6. u2phydcr0(0xb0120860)=0x00aaaa02
FM_OUT value: u4FmOut = 0(0x00000000)
FM_OUT value: u4FmOut = 130(0x00000082)
FM detection done! loop = 1
SR calibration value u1SrCalVal = 6
Register 1111 NbrPorts 1
USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning bus for storage devices... 1 Storage Device(s) found
reading root_uImage
<more lines with dots>
16449536 bytes read
Done!
DRAM bus: 16 bit
