wifi wpa2 psk length >51 does not work? - Solved
Posted: Tue Jan 03, 2017 10:20 pm
hello,
got my vocore2 last year already, starting to use it finally. First catch, however, wifi connection between vorcore and hostapd can't be established.
After several ours (first suspect always: special chars) figured out, wpa2 psk key length seems to be a problem. Simple example (hostapd.conf snippet):
Inserted appropriate counterpart at /etc/config/wireless at the vocore, of course.
I don't want to change the key just for this 'cause of other stations. So, maybe anyone can confirm and/or has a workaround at hand?
Of course, already searched for the net a lot.
As there are exactly 12chars missing to max of 63chars, I suspect bssid (default: mac-address, 12chars) is perhaps related in some way..
thanks®ards
## does not work, 52chars
wpa_passphrase=0123456789012345678901234567890123456789012345678901
## works, 51chars
thanks®ards
