Hi
My vocore2 arrived but it only works when its is out from the case
The first 2 pictures show how bad the 2 boards fit together and in the last one you can see how misaligned us the audio port with the case.
When I try to align the Ethernet port and the audio port and close the case the 2 boards disconnect from each other and vocore does not start.
Anyone else experienced this problem ?
Vocore2 ultimate factory problem?
- irinelturturea
Re: Vocore2 ultimate factory problem?
1. insert the 3.5mm headphone to the audio port.
2. correct its position, align it.
3. push at another side, insert the audio port to the shell hole.
- irinelturturea
Yeah
I tried but when i do that the 2 boards disconect from eachother and then vocore board is not getting power anymore. I susspect also other pins will not be proprely plugged between the 2 boards.
irinelturturea wrote:Yeah
- cory
your best option is to go to local high school, look for some science teacher preferably in robotic field, ash him to 'fix' the board for you.
Users browsing this forum: Google [Bot] and 46 guests
