Setup AP + STA Mode
- cory
Re: Setup AP + STA Mode
google vi tutorial basically you want to learn how to get in, how to quit without saving, how to save and get out, what is insert mode, what is append mode, you already know how to move around by arrow keys.
- herci
okay I was able to change everything into this
config wifi-device 'radio0'
option type 'ralink'
option variant 'mt7628'
option country 'CN'
option hwmode '11g'
option htmode 'HT40'
option channel 'auto'
option disabled '0'
config wifi-iface 'ap'
option device 'radio0'
option mode 'ap'
option network 'lan'
option ifname 'ra0'
option ssid 'VoCore2'
option encryption 'none'
option disabled '0'
config wifi-iface 'sta'
option mode 'sta'
option network 'wwan'
option ifname 'apcli0'
option encryption 'psk'
option ssid 'telenet-apn-D4F49'
option key 'correctkey'
option disabled '0'
unfortunately I now lost internet connection with the vocore, doesn't show up anymore, I rebooted multiple times
But I see vocore2 in airplay sometimes and when I try it, I hear cracking. So I guess it must have worked?? And it's normal that I don't see vocore2 anymore in the network.
But there are severe sound issues with this thing. And the connection to vocore in the airplay menu is at times gone. Multiple efforts later I got it playing decent sound in spotify.
So thank you everyone for helping out. Really appreciate it.
option country 'CN'
option hwmode '11g'
option disabled '0'
option mode 'ap'
option ifname 'ra0'
option disabled '0'
option mode 'sta'
option disabled '0'
I upload a youtube video, please search VoCore2 on youtube
- bazz
Vonger wrote:I upload a youtube video, please search VoCore2 on youtube
I checked the video, but have the same problem as the op. Cant get it to work for the life of me..
I put a video tutorial on youtube, please search VoCore2, AP+STA mode.
- Ictinike
I read the OP's first message and it states he used PUTTY, which is fine if it's a SERIAL connection.
In the tutorial Vonger states you can't use SSH for doing this but must be done via SERIAL UART so my first question would be; is that being done?
Secondly, in the tutorial it is mentioned that the use of quotes to encapsulate the values since sometimes UCI does not do them properly. I have gotten into the habit, when modifying UCI files via SERIAL, to use a set of double quotes to make sure things 'stick' such as:
I used to not use quotes or single quotes and it *seemed* to work but values would not be read properly. As soon as I started doing them with double quotes, again via SERIAL; things worked.
Lastly, are commits being made using UCI after commands are entered? I've gotten into the habit of doing two commits (overkill, I know) but I have done them and between reboots they've not 'stuck'. After doing a few commands or in a script you must commit to save the changes and persist them in the /etc/config/<config_name> file.
Just a few things after reading the first page that came to mind. You may have already discussed this so if they were recommended; I apologize.
uci set wireless.sta.encryption="psk2"
uci commit
- bazz
Was the Op ever able to get this to work? I'm still having no luck. Perhaps the type of encryption needs to be set? I followed the direction and the wiki and the youtube.
Users browsing this forum: No registered users and 40 guests
