VoCore2 Lite Monitor Mode
Posted: Thu Jan 19, 2017 8:17 pm
Hi. Has anyone had success setting VoCore2 Lite in monitor mode for wireless packet capture?
airmon-ng reports that chipset is Ralink 2560 PCI rt2500.
aircrack compatibility tables says that "The entire rt2x00 family: rt2400pci, rt2500pci, rt2500usb, rt2800pci and rt2800usb can inject and monitor. Including PCI and USB chips on b/g/n".
http://www.aircrack-ng.org/doku.php?id=compatibility_drivers&DokuWiki=c4a36903831ab7b2c40874416f5f8ea6#compatibility
Seems like it should work. If I try to start capture on airmon-ng, it will say "monitor mode enabled" but iwconfig reports that it is still in "Managed" mode.
Not an expert on chipsets and drivers, but maybe it is related to missing nl80211?
System is Linux OpenWrt 3.18.29 #32 Sat Dec 24 22:01:05 CST 2016 mips GNU/Linux with VoCore firmware from 20161224.
Thanks.
root@OpenWrt:~# airmon-ng start ra0
Interface Chipset Driver
ra0 Ralink 2560 PCI rt2500 (monitor mode enabled)
apcli1 Ralink 2560 PCI rt2500
apcli0 Ralink 2560 PCI rt2500
root@OpenWrt:~# iwconfig
eth0.1 no wireless extensions.
lo no wireless extensions.
ra0 RTWIFI SoftAP ESSID:"VoCore2"
Mode:Managed Frequency=2.437 GHz Access Point: B8:D8:12:67:32:BB
Bit Rate=54 Mb/s Tx-Power=17 dBm
Link Quality=10/100 Signal level:0 dBm Noise level:-77 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
apcli1 RTWIFI SoftAP ESSID:""
Mode:Managed Frequency=2.437 GHz Access Point: Not-Associated
Bit Rate:54 Mb/s Tx-Power=17 dBm
eth0 no wireless extensions.
apcli0 RTWIFI SoftAP ESSID:"VC-Test"
Mode:Managed Frequency=2.437 GHz Access Point: E4:8D:8C:09:04:86
br-lan no wireless extensions.
eth0.2 no wireless extensions.
root@OpenWrt:~# iw dev ra0 info
nl80211 not found.
Thanks.
