No Default Gateway w/ Static IP
Posted: Sun Feb 26, 2017 5:07 am
Group,
Been trying to figure this out as it seems to have been, or continues to be, an issue in OpenWRT.
Upon configuring AP+STA mode I can completely and 100% get it work in DHCP mode:
However, the moment I setup the client STA into a static IP mode [which I prefer here on the compound] I have my issues. See I'm able to configure it and I get connected with the proper IP I've chosen but for some reason OpenWRT won't assign a 'default' gateway' to the routes. For purposes, here is my config if I so go into STATIC mode:
This works wonderfully, however, I cannot get out to the Internet at large. If I do a ping, I get 'bad address' since there is no default gateway created upon bootup. Now if I add one in by issuing 'route add default gw 192.168.1.1 apcli0' everything works fine until reboot, wherein I must re-add the route.
I've been searching and have found this issue in OpenWRT all the way about to nearly 8-10 years ago and there were many suggestions, ideas, etc but none that I have tried worked. In fact on one conversation they just asked the person to use DHCP because it was 'easier'. Blarg!
What's even more ridiculous is I have a few Onion Omega2+ from awhile back and they also run OpenWRT LEDE which, if I configure a static IP for it; it acts the *very* *same* *way*! So this is why I'm thinking it's something I'm not doing properly or at all so thought I would present it to the larger audience and see what might come from it.
Thanks!
~Icky
uci show network.wwan
network.wwan=interface
network.wwan.ifname='apcli0'
network.wwan.proto='dhcp'
network.wwan.proto='static'
network.wwan.ipaddr='192.168.1.116'
network.wwan.netmask='255.255.255.0'
network.wwan.gateway='192.168.1.1'
network.wwan.dns='192.168.1.115'
Thanks!
~Icky
