REFCLK Pin?
Posted: Wed Mar 01, 2017 5:52 am
by joechen
What is the situation where you need to connect anything to the Pin REFCLK?
I am laying out a breakout board for this vocore2 and thinking not to connect anything to it at all. Will I miss anything if I do so?
Re: REFCLK Pin?
Posted: Fri Mar 03, 2017 2:02 am
joechen wrote:What is the situation where you need to connect anything to the Pin REFCLK?
REFCLK is for audio codec.
Re: REFCLK Pin?
Posted: Sun Mar 05, 2017 7:23 am
by joechen
Vonger wrote:joechen wrote:What is the situation where you need to connect anything to the Pin REFCLK?
Thanks Vonger. Further reading the datasheet, pin REFCLK seems to also work as one of GPIOs with a correct pin mux setting. Am I correct?
