Idea about mechanical design optimisation for VoCore 3
Posted: Fri Mar 24, 2017 4:11 pm
Just received NanoPi NEO 2 which has as well eth port.
I found that eth socket used in VoCore2 is about 2.5mm taller that this one used in NanoPi.
If such eth socket will be used in VoCore I think it would be possible to rotate uSD card slot to mount it parallel to MB in such gap between eth port on EXT board and MB.
After this it will be necessary to move on the side all wires connecting MB with ext board which are now between uSD card socket and USB socket.
With such mechanical design it will be no issue with plugging everything to VoCore and now it is issue with plugging uSD card and mUSB.
kloczek
kloczek
