yes, i personally would like to capture a yubikey with it to use authentication via the yubikey server api with curl (i seen that is available in the packages) to use it as a sort of electronic lock with one singe potential identifier (which is me unless they steal my key) but dmesg gives
root@fuckpencilpushingnazis:/dev# dmesg
[ 0.000000] Linux version 3.18.29 (vocore@ubuntu) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r49378) ) #32 Sat Dec 24 22:01:05 CST 2016
[ 0.000000] Board has DDR2
...yadda yadda about 100 lines...
...yadda yadda another 100 lines ...
[ 6.180000] sdhci: Secure Digital Host Controller Interface driver
[ 6.190000] sdhci: Copyright(c) Pierre Ossman
[ 6.200000] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.210000] usbcore: registered new interface driver usb-storage
[ 6.300000] mmc0: new SD card at address 159e
[ 6.300000] mmcblk mmc0:159e: no of_node; not parsing pinctrl DT
[ 6.310000] mmcblk0: mmc0:159e SD064 59.1 MiB
[ 6.310000] mmcblk0: p1
...this part (i think says the microsd 64mb cars is recognized, partition is mounted? ...
[ 6.440000] init: - preinit -
...yadda yadda... another 70 lines of startup...
[ 59.460000] random: nonblocking pool is initialized
<<-- that part gave me a headache when i first tried booting it after flashing firmware ...
THEN
[ 410.910000] usb 1-1: new high-speed USB device number 6 using ehci-platform
thats a 4GB usb flashdrive, it gives no errors but i dont see what device which is probably due to my lamer nubness ...
THEN
[ 542.640000] usb 2-1: new low-speed USB device number 4 using ohci-platform
[ 542.830000] usb 2-1: device descriptor read/64, error -62
[ 543.120000] usb 2-1: device descriptor read/64, error -62
[ 543.410000] usb 2-1: new low-speed USB device number 5 using ohci-platform
[ 543.600000] usb 2-1: device descriptor read/64, error -62
[ 543.890000] usb 2-1: device descriptor read/64, error -62
[ 544.180000] usb 2-1: new low-speed USB device number 6 using ohci-platform
[ 544.600000] usb 2-1: device not accepting address 6, error -62
[ 544.780000] usb 2-1: new low-speed USB device number 7 using ohci-platform
[ 545.200000] usb 2-1: device not accepting address 7, error -62
[ 545.200000] usb usb2-port1: unable to enumerate USB device
is what happens when i insert the yubikey ... the green led blinks exactly in sync with the error 62s (which i have no clue what that means) and then i just goes out
my idea was if that thing can get input from a camera it can get input from a whatever fits the slot, no ? but this is at machine level , no ? some kind of driver problem ?
which would make it way above my capabilities unless someone can point me to a this bit goes there type manual ?
im not the dullest tool in the shed but in the world of electronics compared to you ppl im a total nub, apologies
but it <b>would</b> be cool to just use a yubikey in a vocore connected to i dont know what, i suppose even a lock since the authentication happens serverside you'd have to break through the wall to intercept the signal through the cables
and yes i know, if the ISP goes down you're screwed, its just a concept and im sure it can work but i have no clue where to start with this
