Madplay "bites off the last word"
Posted: Thu Apr 06, 2017 2:29 am
I been trying plenty of stuff, im trying to use the cube as a "voice server" to speak certain sentences or make sentences up from words stored as mp3 on an inserted sd card now, thing is
mp3s that dont have one or two seconds of silence are like "bitten off" at the end, for example :
where 0-320.mp3 is a completely empty mp3, i got some other comparisons, and a lot of rabble which i keep on my homeblog here : http://www.alleycat.be/tulz/re-pliables/contents/howto.php?include=14
leads me to believe that for some reason the audio device is closed too soon, since it plays a sample that goes "did you bar the door" which has like a full second of zero sound at the end where as the other one "did you close the door" loses the last word
playing mp3s in a list plays all mp3s complete except the last one. I dont want to use "whitespace" mp3s b/c this would use more resources than needed and prefer not to record the samples with whitespace at the end (pardon the jargon) to save space on the sd card which has 64mb only and because its more elegant to do so.
also any .wav or .aiff i convert with audacity it wont play so , technically i could fix it by recording all sentences with a full second of silence at the end but i dont know how this would affect "constructed sentences" like for instance to speak a report on the day dates and numbers would be made out of chunks or words.
If anyone can think of any solution to make an mp3 play completely without using tricks and hackarounds id be much obliged, maybe im simply missing something or maybe madplay wasnt built for this ?
Any advice welcome i cant find any other package to replace madplay with either so far if thats a solution but it would have to be as lightweight as possible
thanks in advance i hope my explanation was not too confusing lol
root@fuckpencilpushingnazis:/mnt/mmcblk0p1# madplay 4-320.mp3
MPEG Audio Decoder 0.15.2 (beta) - Copyright (C) 2000-2004 Robert Leslie et al.
Artist: http://www.acapela-group.com/ - Valeria
51 frames decoded (0:00:01.3), -5.8 dB peak amplitude, 0 clipped samples
root@fuckpencilpushingnazis:/mnt/mmcblk0p1# madplay 4-320.mp3 0-320.mp3
>> 4-320.mp3
>> 0-320.mp3
8 frames decoded (0:00:00.2), -44.3 dB peak amplitude, 0 clipped samples
root@fuckpencilpushingnazis:/mnt/mmcblk0p1# madplay 4-320.mp3 0-320.mp3 0-320.mp3
>> 4-320.mp3
>> 0-320.mp3
>> 0-320.mp3
</PRE>
gives something like <br>
<ul>
<li>did you close the doh</li>
<li>did you close the dor</li>
<li>did you close the door</li>
</ul>
