Hi guys!
I buy a basic configuration of VoCore2, and I thought what is simple will solder RX+ - TX+ - to a P0RP P0RN P0TP P0TN , but I have now understood that I was mistaken. Before I didn't deal with any version VoCore
From here viewtopic.php?f=10&t=400 I have found out, what need for vocore v1 that use ethernet port.
Ok, where I need to give 3.3 volts? Or version 2 doesn't give such chance? Or only to do the transformer?
Before beginning to do something, I need to learn your opinion.
VoCore2 ethernet without Dock
- nbash
Re: VoCore2 ethernet without Dock
please check vocore2 ultimate hardware schema, follow it the ethernet will work, a RJ45 with transformer is better.
- nbash
Hi!
it was necessary to look for the donor with the coordinating transformer and actually, port. The non-working network interface card from a satellite receiver has acted as the donor:
Also the printed circuit board is manufactured (sprint layout 6):
According to the scheme from a datasheet to the HR911105A socket:
Thus, VoCore2 works with ethernet at me for more than one month.
http://www.kosmodrom.com.ua/pdf/HR911105A.pdf
https://linux-connect.ru/sites/default/files/vocore-rj45.lay6
Users browsing this forum: No registered users and 58 guests
