Is there a way to fully dump de files and configurations of a Vocore2 to duplicate it in another one ?
I would like to develop on the Vocore that i soldered on a breadboard and when all is ready, dump all the files and configuration in another vocore which will go in the final system without needing to reconfigure everything step by step.
Full dump for duplicate
- avigeilpro
Re: Full dump for duplicate
Lots of ways to do that, here is one.
cat /proc/mtd shows the flash partitions
rootfs contains the last image you flashed, rootfs_data contains the changes since then.
- avigeilpro
thank you noblepepper, for what i want do, i think the easier way is to generate an archive through the web interface (System > Backup / Flash Firmware > Generate Archive), am I right ? Or is it better to do a backup of mtd4 (rootfs_data) ?
If all you need is configuration the Luci web interface option does that. If you install packages, you will need to install them again on a new board. The mtd approach will get both.
I like to configure a image that contains all the packages I want then use uci-defaults to set configurations. This way when you flash the image the only changes that are needed on rootfs_data are the configurations, leaving more "disk" space. It takes a bit more fiddling I look at it as the "right way".
- avigeilpro
I want test the mtd approach, so i did this :
then this :
I have my rootfs_data.backup file and saved it on another computer.
My question is how do i do to restore now, i read that i need use the "mtd" command, but i'm not sure about the exact way to do and i dont want do any mistake.
root@OpenWrt:~# cat /proc/mtd
dev: size erasesize name
mtd0: 00030000 00010000 "u-boot"
mtd1: 00010000 00010000 "u-boot-env"
mtd2: 00010000 00010000 "factory"
mtd3: 00fb0000 00010000 "firmware"
mtd4: 00117d92 00010000 "kernel"
mtd5: 00e9826e 00010000 "rootfs"
mtd6: 00910000 00010000 "rootfs_data"
then this :
dd if=/dev/mtd6 of=/tmp/rootfs_data.backup
root@vocore2:/# mtd
Usage: mtd [<options> ...] <command> [<arguments> ...] <device>[:<device>...]
The device is in the format of mtdX (eg: mtd4) or its label.
mtd recognizes these commands:
unlock unlock the device
refresh refresh mtd partition
erase erase all data on device
verify <imagefile>|- verify <imagefile> (use - for stdin) to device
write <imagefile>|- write <imagefile> (use - for stdin) to device
jffs2write <file> append <file> to the jffs2 partition on the device
fixseama fix the checksum in a seama header on first boot
Following options are available:
-q quiet mode (once: no [w] on writing,
twice: no status messages)
-n write without first erasing the blocks
-r reboot after successful command
-f force write without trx checks
-e <device> erase <device> before executing the command
-d <name> directory for jffs2write, defaults to "tmp"
-j <name> integrate <file> into jffs2 data when writing an image
-s <number> skip the first n bytes when appending data to the jffs2 partiton, defaults to "0"
-p write beginning at partition offset
-l <length> the length of data that we want to dump
Example: To write linux.trx to mtd4 labeled as linux and reboot afterwards
mtd -r write linux.trx linux
root@vocore2:/#
So using the example
mtd -r write /tmp/rootfs_data.backup rootfs_data
Will write the file to the mtd6 section of the flash and reboot when it is done.
- avigeilpro
Users browsing this forum: Google [Bot] and 8 guests
