I was toying around in the LuCI interface and I accidentally enabled SSID in the network section. I saw the VoCore doing something in the Tera Term window and after that I was unable to find the VoCore2 in my Wifi list on my PC
I am a complete noob to both VoCore2 and OpenWrt.
Is there a way to reset this or change these settings?
Thanks
Don't see VoCore2 in Wifi list
- joshryan
Re: Don't see VoCore2 in Wifi list
First connect to VoCore through USB2TTL, -- the Tera, I see you have connected it.
Then once the boot ready, press "return", check command line, shows "OpenWrt > " or similar.
Type "firstboot -y" return, then call reboot at Tera. After that, everything will back normal.
Users browsing this forum: No registered users and 39 guests
