Segmentation fault
Posted: Mon May 15, 2017 4:37 pm
by pablocarrio
I've made a c++ program toggle a gpis pin, for this I've made a small class for controlling the gpis ports, I've achieved compile the code in Ubuntu 14.04 as explained in the documentation but when I upload and run it I get "Segmentation fault" in the console. First I got this error "./gpio: can't load library 'libstdc++.so.6'" but I installed libstdcpp package and was solved. If anyone can help me please
Here is the code:
gpio.cpp
#include <stdio.h>
#include "gpio.h"
/******** GPIO ***********/
PinOut GPIO::setOutput(int pinId){
    PinOut pin(pinId);
    return pin;
PinIn GPIO::setInput(int pinId){
    PinIn pin(pinId);
    return pin;
/*********** Pin **********/
Pin::Pin(int pinId){
    this->pinId = pinId;
    this->exportPin();
Pin::~Pin(void){
    this->unexportPin();
bool Pin::state(void){
    int state = 0;
    char dir[50];
    sprintf(dir,"/sys/class/gpio/gpio%d/value", pinId);
    FILE *file;
    file = fopen(dir, "r");
    fscanf (file, "%d", &state);
    fclose (file);
    return (bool)state;
void Pin::exportPin(void){
    FILE *file;
    file = fopen("/sys/class/gpio/export", "w");
    fprintf(file,"%d",this->pinId);
    fclose(file);
void Pin::unexportPin(void){
    FILE *file;
    file = fopen("/sys/class/gpio/unexport", "w");
    fclose(file);
/******** PinOut ************/
PinOut::PinOut(int pinid):Pin(pinid){
    Pin pin(pinId);
    char dir[50];
    sprintf(dir, "/sys/class/gpio/gpio%d/direction", pinId);
    FILE *file;
    file = fopen(dir, "w");
    fprintf(file,"out");
    fclose(file);
void PinOut::setPin(void){
    char dir[50];
    sprintf(dir, "/sys/class/gpio/gpio%d/value", this->pinId);
    FILE *file;
    fprintf(file,"1");
    fclose(file);
void PinOut::clearPin(void){
    char dir[50];
    FILE *file;
    fprintf(file,"0");
    fclose(file);
void PinOut::writePin(bool val){
    char dir[50];
    FILE *file;
    fprintf(file,"%d",val);
    fclose(file);
void PinOut::togglePin(void){
    //int newstate = !
    this->writePin((int)~this->state());
/********* PinIn ***********/
PinIn::PinIn(int pinid):Pin(pinid){
    Pin pin(pinId);
    char dir[50];
    FILE *file;
    fprintf(file,"in");
    fclose(file);
gpio.h
#ifndef gpio
#define gpio
typedef enum {GPIO0, GPIO1, GPIO2, GPIO3, GPIO4, GPIO5, GPIO6, GPIO7, GPIO8, GPIO9, GPIO10, GPIO11, GPIO12, GPIO13, GPIO14, GPIO15, GPIO16, GPIO17, GPIO18, GPIO19, GPIO20, GPIO21, GPIO22, GPIO23, GPIO24, GPIO25, GPIO26, GPIO27, GPIO28, GPIO29, GPIO30, GPIO31, GPIO32, GPIO33, GPIO34, GPIO35, GPIO36, GPIO37, GPIO38, GPIO39, GPIO41, GPIO42, GPIO43, GPIO44 } PinId;
class Pin{
    public:
        bool state(void);
        Pin(int pinId);
        ~Pin(void);
    protected:
        void exportPin(void);
        void unexportPin(void);
        int pinId;
class PinOut: public Pin{
    public:
        void setPin(void);
        void writePin(bool val);
        void clearPin(void);
        void togglePin(void);
        PinOut(int pinid);
class PinIn: public Pin{
    public:
        void setPin(void);
        PinIn(int pinId);
class GPIO{
    public:
        static PinOut setOutput(int pinId);
        static PinIn setInput(int pinId);
#endif
main.c
#include <stdio.h>
#include "gpio.h"
int main(void){
    PinOut led = GPIO::setOutput(GPIO41);
    led.togglePin();
    return 0;
Re: Segmentation fault
Posted: Wed May 17, 2017 7:07 am
Segmentation fault issue normally is your missed some library. default vocore2 do not install c++ library. You need to ocmpile new openwrt with the cpp library or install cpp library to vocore2 by ipk.
Posted: Thu May 18, 2017 11:50 am
by avigeilpro
Hi, personally I use this library :
gpio.h
#include <sys/stat.h>
#include <sys/types.h>
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#ifndef _GPIO_H
#define _GPIO_H
#define IN  0
#define OUT 1
#define LOW  0
#define HIGH 1
static int
GPIOExport(int pin)
#define BUFFER_MAX 3
   char buffer[BUFFER_MAX];
   ssize_t bytes_written;
   int fd;
   fd = open("/sys/class/gpio/export", O_WRONLY);
   if (-1 == fd) {
      return(-1);
   bytes_written = snprintf(buffer, BUFFER_MAX, "%d", pin);
   write(fd, buffer, bytes_written);
   close(fd);
   return(0);
static int
GPIOUnexport(int pin)
   int fd;
   fd = open("/sys/class/gpio/unexport", O_WRONLY);
   if (-1 == fd) {
      return(-1);
   close(fd);
   return(0);
static int
pinMode(int pin, int dir)
   static const char s_directions_str[]  = "in\0out";
#define DIRECTION_MAX 35
   char path[DIRECTION_MAX];
   int fd;
   snprintf(path, DIRECTION_MAX, "/sys/class/gpio/gpio%d/direction", pin);
   fd = open(path, O_WRONLY);
   if (-1 == fd) {
      return(-1);
   if (-1 == write(fd, &s_directions_str[IN == dir ? 0 : 3], IN == dir ? 2 : 3)) {
      return(-1);
   close(fd);
   return(0);
static int
digitalRead(int pin)
#define VALUE_MAX 30
   char path[VALUE_MAX];
   char value_str[3];
   int fd;
   snprintf(path, VALUE_MAX, "/sys/class/gpio/gpio%d/value", pin);
   fd = open(path, O_RDONLY);
   if (-1 == fd) {
      return(-1);
   if (-1 == read(fd, value_str, 3)) {
      return(-1);
   close(fd);
   return(atoi(value_str));
static int
digitalWrite(int pin, int value)
   static const char s_values_str[] = "01";
   int fd;
   if (-1 == fd) {
      return(-1);
   if (1 != write(fd, &s_values_str[LOW == value ? 0 : 1], 1)) {
      return(-1);
   close(fd);
   return(0);
static int
digitalToggle(int pin){
   digitalWrite(pin, 1 - digitalRead(pin));
   return(0);
#endif /* !_GPIO_H */
exemple of usage :
main.cpp
#include <stdio.h>
#include <gpio.h>
int main(void){
    int led = 38;
    GPIOExport(led);  //export Pin
    pinMode(led,OUT);
    digitalWrite(led,HIGH); //turn on pin
    usleep(1000000);  // sleep 1s
    digitalWrite(led,LOW);  //turn off pin
    usleep(1000000);  //sleep 1s
    digitalToggle(led); //toggle pin
    GPIOUnexport(led);
    return 0;
I have put the gpio.h file in the folder "openwrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/include" of my VM machine.
