I am new to Vocore2. I was setting it up and for some reason when i try to use my mac to screen command it through terminal it is giving me an error and will not continue.
My command is as such:
screen /dev/tty.usbmodem_____1
The output i receive is as follows:
[ 6.170000] mtk-sd: MediaTek MT6575 MSDC Driver
te
[ 71.050000] efuse_probe: efuse = 10000002
[ 71.050000] net ra0: Direct firmware load for mt7628.eeprom failed with error -2
[ 71.060000] net ra0: Falling back to user helper
[ 72.040000] br-lan: port 1(eth0.1) entered forwarding state
[ 76.660000] tssi_0_target_pwr_g_band = 35
[ 76.660000] tssi_1_target_pwr_g_band = 35
[ 81.670000] <==== rt28xx_init, Status=0
[ 82.730000] device ra0 entered promiscuous mode
[ 82.740000] br-lan: port 2(ra0) entered forwarding state
[ 84.740000] br-lan: port 2(ra0) entered forwarding state
I restarted my device and tried again and getting the below only where it stopped:
[ 6.120000] hub 2-0:1.0: USB hub found
[ 6.120rwarding state
[ 25.390000] br-lan: port 1(eth0.1) entered forwarding state
[ 26.690000] efuse_probe: efuse = 10000002
[ 26.900000] tssi_0_target_pwr_g_band = 35
[ 26.910000] tssi_1_target_pwr_g_band = 35
[ 27.390000] br-lan: port 1(eth0.1) entered forwarding state
[ 28.940000] random: nonblocking pool is initialized
[ 33.250000] <==== rt28xx_init, Status=0
[ 34.100000] device ra0 entered promiscuous mode
[ 34.100000] br-lan: port 2(ra0) entered forwarding state
[ 34.110000] br-lan: port 2(ra0) entered forwarding state
[ 36.110000] br-lan: port 2(ra0) entered forwarding state
please let me know what i am doing wrong and how to make it work.
Thanks,
trying to screen to Vocore2
- ash
Re: trying to screen to Vocore2
weird, it is possible to be power issue, try reboot, stopped same position?
If it stops randomly, might be power issue.
Or try to use kermit upgrade the firmware.
Users browsing this forum: No registered users and 120 guests
