VoCore2 U.FL Antenna Only
hyyoon
Fri Jul 07, 2017 1:05 pm
Hi all,
I just found that the secondary antenna for wifi on vocore2 is disabled by default. So this is SISO with onboard antenna by default. The link below gives commands to bring the second antenna up to get MIMO working which might require at least 6cm spacing between the two antennas to prevent cross talks.
Is there any command to disable the power of the onboard antenna? I'd like to use the secondary antenna only while turning off the onboard antenna. This way I could hook up with high gained antenna connected to U.FL to get better coverage.
http://vocore.io/v2.html
enable second antenna:
/tmp/factory 0x34 0x22 > /tmp/mtd2.tmp
mtd -e factory write /tmp/mtd2.tmp factory
disable second antenna:
/tmp/factory 0x34 0x11 > /tmp/mtd2.tmp
Re: VoCore2 U.FL Antenna Only
Sun Jul 09, 2017 2:13 pm
I think there is a way :) but need to check its wifi driver source code, directly control from its driver...no other way.
Actually you can do a lot of things if you modify its driver, such as mutli-ssid etc, I am trying to understand it recently :)
hyyoon
Tue Jul 25, 2017 3:12 am
Thanks, I'll look up something from the source code.
nbash
Mon Jul 31, 2017 6:57 pm
I too thought about that feature and have found EEPROM Base address in mt7628.pdf http://vonger.cn/misc/vocore2/datasheet.zip:
it's a right way?
Fri Aug 11, 2017 12:17 pm
That config is used to enable 1 antenna or 2 antennas, can not control which one to enable.
nbash
Fri Aug 11, 2017 2:00 pm
What else I have noticed:
Is that operation, works as AUX (RX only) in mini pci-e wireless card from notebook. Not 2T2R. Probably that is specific feature of wifi drivers, but I doubt.
The question remains open.
Users browsing this forum: No registered users and 71 guests
