VoCore2 Lite connection lost, factory reset might be needed
Posted: Thu Jul 27, 2017 7:18 am
Hello all,
I have VoCore2 Lite, i tried to connect it to my home network through web interface and unfortunately i cant see it in the network now and cant see its IP. I am pretty sure that the device is working but i have no connection with it! My only connection with the device was through WiFi - web and SSH.
I have no second VoCore and cant reflash it this way
I have no access through USB2TTL either, as may be the cable that i am using is not good. The device manager shows that it is not recognized USB device, and no drivers can be installed. Something more, for me it is not clear which wire where to go. Right now i am using straight USB cable D+ go to RXD2 and D- go to TXD2 and that way the USB gets not recognition and cant install any drivers (i am doing it on Windows 10). I am using same cable for powering.
Is there any chance to reset the device to factory default settings just like some routers, with let say 10+ seconds of holding the reset or other procedure.
Regards!
Regards!
