Hi All
I hope some one here can be of assistance, new to the world of Vocore2;
I have completely halted my system, here is the output from TTL via windows using putty;
<snip>
*** Warnirigger enabled
GPIO 46 is low
You chose 3
0
Image Name: MIPS OpenWrt Linux-3.10.49
Data Size: 1006224 Bytes = 982.6 kB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
No initrd
Starting kernel ...
<snip end>
The system is now frozen, any help would be appreciated. Point me in the right direction, many thanks in advance.
jnike1
When firmware update goes wrong!!
- jnike1
Re: When firmware update goes wrong!!
default we are using UART2 as debug port, looks like your firmware is not using VOCORE2.dts, so debug console is changed after you update the firmware.
Try to fix your firmware and make it using UART2 as debug console port, then use kermit and uboot upload the firmware, it will recover.
PS: VoCore2 firmware default enable wifi, but if you compile from openwrt/lede, wifi is default off. you can connect to your VoCore2 by ethernet and setting /etc/config/wireless, remove the disable setting.
- jnike1
Thanks for the reply Vonger,
but no joy using kermit, the port /dev/ttyACM0 connects but no response from Vocore2. I also tried connecting to the device via ethernet, but also dead no response(tried both 192.168.1.1 & 192.168.61.1after some reading).
Thanks for your prompt suggestions.
jnike1
jnike1
That's bad, try vocore.io/v2.html fix brick section.
- jnike1
Users browsing this forum: No registered users and 115 guests
