i want to configure my vocore2 for establish an internal network without connection to the internet.
DHCP server should listen on all interfaces.
Example:
I have a small device, what is a music server (DLNA). This device is headless and i need connection to LAN via cable. To play music and to control the server i can use WiFi. But the vocore doesn't provide DHCP at the cable port.
Is it possible to do, what i want? How can i reach it?
Thanks,
Schultze
routing between wifi and cable
- der.schultze
Re: routing between wifi and cable
I am not sure if I understand you. I guess you want to make ethernet port alloc ip for your device?
In /etc/config/network, you can setup the virtual network proto as 'dhcp', then it will alloc ip for device connect to it. check that file and openwrt site have a documentation about setting that.
- der.schultze
Hm, is there a possibility via web-ui?
I think, when i set proto as 'dhcp', it will be a client. Or?
Thanks,
Schultze
Thanks,
Schultze
Users browsing this forum: No registered users and 96 guests
