hello i have a new vocore 2 i lost wifi , pls can some one post here a tested config of wifi config pls
i need 2 files config
etc/config/network file and etc/confg/wireless pls a working tested config , i spend 2 hours to try but without success
thx
new user problem with wifi
- chotky
Re: new user problem with wifi
If you are still able to connect to its console, try to call "firstboot -y" and reboot, you will get back default config.
- chotky
Im conecter with usb ttl will try to got default config bit what i need is tested 2 files for network config and wifi config thx
You can go to openwrt.org check the wifi/network setting, we also have tutorial at vocore.io/v2.html and youtube
If you want the vocore to connect to the internet through your home wifi this thread has before and after example of /etc/config/wireless for after you do firstboot -y /etc/config/network doesn't need any changes.
Users browsing this forum: No registered users and 115 guests
