Vocore 2 Lite Wifi still Crashes. Help? Any updates?
Posted: Thu Aug 31, 2017 4:46 pm
by rkk
I'm trying to make a OpenVPN gateway from my Vocore 2 Lite, but the frequent Wifi crashes makes it impossible to do anything reliable with it.
So far I tried every compatible firmware I could find (The outdated Official one from http://vocore.io/v2.html, and the LEDE one from https://lede-project.org/toh/hwdata/voc ... core2_lite). None seems to make the Wifi work properly. The official one is painfully slow (2Mbit peak transfer) with random disassociation, while the LEDE one seems to work faster (21Mbit peak transfer) but has the same disassociation issues, including a frequent Kernel Panic that leaves the system in a limbo like state, where it cannot connect to the Wifi anymore till I restart the device.
After several months, so far I haven't seen any intentions from the creator of Vocore2 (Vonger) to do something about it and update the firmware to something that is hopefully stable (Or am I missing out something?).
How is it looking for the Vocore 2 (Non-Lite) users? Is it more stable? Is there any anouncements for any updates for the buggy firmwares? Any workarounds to make the Vocore 2 Lite's Wifi more stable? Any input on this from Vonger?
P.D: Here is the kernel panic log, in case somebody has an idea what is going wrong:
root@LEDE:/etc/config# iperf3 -c 192.168.2.254 -f M
Connecting to host 192.168.2.254, port 5201
[  5] local 192.168.2.151 port 48794 connected to 192.168.2.254 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec  65.0 KBytes  0.06 MBytes/sec    3   1.41 KBytes
[  5]   1.00-2.00   sec  0.00 Bytes  0.00 MBytes/sec    0   1.41 KBytes
[ 8735.573010] MCU message 40 (seq 8) timed out
[  5]   2.00-3.00   sec  0.00 Bytes  0.00 MBytes/sec    0   1.41 KBytes
[ 8736.612933] MCU message 8 (seq 9) timed out
[  5]   3.00-4.00   sec  0.00 Bytes  0.00 MBytes/sec    0   1.41 KBytes
[ 8737.652809] MCU message 40 (seq 10) timed out
[ 8737.659666] ------------[ cut here ]------------
[ 8737.664492] WARNING: CPU: 0 PID: 2264 at /home/buildbot/slave-lede-local/ramips_mt7688/build/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7688/mt76-2017-07-17-3c4c9a64/mt7603_mac.c:1279 mt7603_mac_work+0x12c/0x248 [mt7603e]
[ 8737.684947] Modules linked in: tun pppoe ppp_async pppox ppp_generic nf_conntrack_ipv6 iptable_nat ipt_REJECT ipt_MASQUERADE xt_time xt_tcpudp xt_state xt_nat xt_multiport xt_mark xt_mac xt_limit xt_conntrack xt_comment xt_TCPMSS xt_REDIRECT xt_LOG xt_CT slhc nf_reject_ipv4 nf_nat_redirect nf_nat_masquerade_ipv4 nf_conntrack_ipv4 nf_nat_ipv4 nf_nat nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_rtcache nf_conntrack iptable_mangle iptable_filter ip_tables crc_ccitt mt76x2e mt7603e mt76 mac80211 cfg80211 compat ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_mangle ip6table_filter ip6_tables x_tables mmc_block sdhci_pltfm sdhci mtk_sd mmc_core leds_gpio ohci_platform ohci_hcd ehci_platform ehci_hcd gpio_button_hotplug usbcore nls_base usb_common
[ 8737.754114] CPU: 0 PID: 2264 Comm: kworker/u2:0 Not tainted 4.9.44 #0
[ 8737.760667] Workqueue: phy0 mt7603_mac_work [mt7603e]
[ 8737.765804] Stack : 83803414 83271918 00000088 8004d710 8399b0ec 8040d307 803be2b0 000008d8
[ 8737.774323]         803be21c 8332bd64 80410000 8007c77c 00000088 8004d710 803c3a74 80410000
[ 8737.782838]         00000003 8332bd64 80410000 80038f40 00000088 8332bd9c 000000d9 00000000
[ 8737.791340]         00000000 00000000 831054f8 83b7f600 83b7f700 30796870 00000000 00000000
[ 8737.799857]         00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 8737.808371]         ...
[ 8737.810853] Call Trace:
[ 8737.813373] [<8000e4c8>] show_stack+0x54/0x88
[ 8737.817812] [<800240a0>] __warn+0xe4/0x118
[ 8737.821970] [<80024168>] warn_slowpath_null+0x1c/0x34
[ 8737.827125] [<83105624>] mt7603_mac_work+0x12c/0x248 [mt7603e]
[ 8737.833079] [<80036f88>] process_one_work+0x1ec/0x32c
[ 8737.838208] [<80037d48>] worker_thread+0x2ac/0x420
[ 8737.843086] [<8003c574>] kthread+0xd8/0xec
[ 8737.847246] [<800093b8>] ret_from_kernel_thread+0x14/0x1c
[ 8737.852722] ---[ end trace 8bebeb313d49910d ]---
[  5]   4.00-5.00   sec  0.00 Bytes  0.00 MBytes/sec    0   1.41 KBytes
[  5]   5.00-6.00   sec  0.00 Bytes  0.00 MBytes/sec    0   1.41 KBytes
[  5]   6.00-7.00   sec  0.00 Bytes  0.00 MBytes/sec    0   1.41 KBytes
[  5]   7.00-8.00   sec  0.00 Bytes  0.00 MBytes/sec    0   1.41 KBytes
[  5]   8.00-9.00   sec  0.00 Bytes  0.00 MBytes/sec    0   1.41 KBytes
[ 8748.132224] MCU message 8 (seq 11) timed out
[ 8749.172167] MCU message 40 (seq 12) timed out
[ 8750.212107] MCU message 8 (seq 13) timed out
[ 8751.252050] MCU message 40 (seq 14) timed out
[ 8752.291992] MCU message 8 (seq 15) timed out
[ 8753.331937] MCU message 40 (seq 1) timed out
[ 8754.371884] MCU message 8 (seq 2) timed out
[ 8755.411822] MCU message 40 (seq 3) timed out
[ 8756.451762] MCU message 8 (seq 4) timed out
[ 8757.491710] MCU message 40 (seq 5) timed out
[ 8758.531650] MCU message 8 (seq 6) timed out
[ 8759.571595] MCU message 40 (seq 7) timed out
[ 8760.611538] MCU message 8 (seq 8) timed out
[ 8761.651485] MCU message 40 (seq 9) timed out
[ 8762.691428] MCU message 8 (seq 10) timed out
[ 8763.731374] MCU message 40 (seq 11) timed out
[ 8764.771320] MCU message 8 (seq 12) timed out
[ 8765.811263] MCU message 40 (seq 13) timed out
And the MCUtimeout messages keep repeating till I reboot the device.
Re: Vocore 2 Lite Wifi still Crashes. Help? Any updates?
Posted: Sat Sep 02, 2017 11:18 pm
Use mediatek openwrt wifi driver or the one from vocore.io, or submit patch to mt76 driver develop at github, the mt76 driver for LEDE is opensource but very unstable, I have said that many times in my blog.
Posted: Thu Sep 14, 2017 3:13 pm
by rkk
Hi @Vonger.
The WiFi with the original Vocore 2 Lite firmware (http://vonger.cn/misc/vocore2/20170211L.bin) is not very stable eider and is very slow.
Can you tell how to install the mediatek openwrt wifi driver in LEDE? Or can you share the firmware you've made with the mt7628.ko in it from your blog (http://vonger.cn/?p=14318)?
