I'm attempting to connect my Vocore2 to the internet to download and install various Python packages for a project. I'm given to understand the AP+STA Mode will allow the vocore to connect to a wireless access point so it can access the internet. However, I still need to maintain access to the device for development purposes. SSH through the parent access point isn't an option. Because of this, I need to enable access through the Vocore's power USB port. I have already attempted soldering the remaining two pins on the USB to the pins directly above on the PCB but Windows device manager doesn't detect it. How can I enable USB communication with the Vocore?
My Vocore is version 2 with the SD Card reader but lacks the dock. The USB port originally only had 4 soldered points with two remaining (which I assumed were there for data but left unsoldered).
Thank you.
Vocore2 AP+STA Mode enable alternative USB connectivity
- www139
Re: Vocore2 AP+STA Mode enable alternative USB connectivity
Please check the sch of VoCore2 Ultimate dock.
You can not directly connect VoCore2 USB+/USB- to your computer, it is a USB host but not USB garget.
You need a USB2TTL(addition device).
Users browsing this forum: No registered users and 64 guests
