kmod-usb-audio kernel missmatch
moiaraya
Sat Nov 18, 2017 11:28 pm
Hi there,
I was trying to install the package kmod-usb-audio for the firmware: http://vonger.cn/misc/vocore2/20170527.bin but I get:
root@OpenWrt:/# opkg install kmod-usb-audio
Installing kmod-usb-audio (3.18.23-1) to root...
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/base/kmod-usb-audio_3.18.23-1_ramips_24kec.ipk.
Multiple packages (kmod-usb-core and kmod-usb-core) providing same name marked HOLD or PREFER. Using latest.
Multiple packages (kmod-sound-core and kmod-sound-core) providing same name marked HOLD or PREFER. Using latest.
Collected errors:
 * satisfy_dependencies_for: Cannot satisfy the following dependencies for kmod-usb-audio:
 *    kernel (= 3.18.23-1-245faaffbc60cabe96a158cae13c1cc3) *
 * opkg_install_cmd: Cannot install package kmod-usb-audio.
The Kernel version is:
root@OpenWrt:/# uname -a
Linux OpenWrt 3.18.29 #5 Sat May 27 16:38:46 CST 2017 mips GNU/Linux
It seems that the package in the repository is too old. However, I didn't find any other repository with a package that satisfies the Kernel dependency.
I want to install it to output the audio through a USB sound card. Any advice? :)
Re: kmod-usb-audio kernel missmatch
Sun Nov 19, 2017 2:50 pm
actually you can force install it, it works normal too.
moiaraya
Mon Nov 20, 2017 11:42 pm
Thanks!
It doesn't work for me just by forcing dependencies though, two modules are still missing:
root@OpenWrt:~# opkg install kmod-usb-audio --force-depends
Configuring kmod-usb-audio.
failed to find a module named snd-usbmidi-lib
failed to find a module named snd-usb-audio
Collected errors:
After that I restarted the VoCore2, and even though the card is recognized as an USB device (it was like that even without kmod-usb-audio), it is not there in the available audio devices of the system:
root@OpenWrt:~# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
root@OpenWrt:~# arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: mt7628audiocard [mt7628-audio-card], device 0: audio-card es8388-hifi-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
I found snd-usbmidi-lib and snd-usb-audio here: https://github.com/adafruit/rpi-firmwar ... /sound/usb but don't know where to copy them.
Should I keep trying to make this kmod work this way or should I try to compile it instead by using the provided Toolchain? If so, can you point me out the source files of kmod-usb-audio and some instuctions for the crosscompilation?
Thanks again!
moiaraya
Tue Nov 21, 2017 12:37 am
Ohhh I found the missing modules in /lib/modules/3.18.23/ so after:
# cp /lib/modules/3.18.23/snd-usb-audio.ko /lib/modules/3.18.29/
# cp /lib/modules/3.18.23/snd-usbmidi-lib.ko  /lib/modules/3.18.29/
and
# opkg configure kmod-usb-audio
Works for me! Now it is recognized:
  Subdevices: 1/1
card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
Now if you want to configure it as the default audio device just follow this instructions: https://www.alsa-project.org/main/index ... ult_device
Thanks for helping :!: :!: :!:
Thu Nov 23, 2017 1:08 am
You wstill need to force install the missing package too.
Another better way is to ocmpile from the source, then you can get everything normal.
Users browsing this forum: Bing [Bot] and 3 guests
