Startup error
Valeron70
Startup error
Sat Dec 23, 2017 4:28 pm
Yesterday I updated the firmware 20170527V.bin, and board worked fine.
Today I see :
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
RESET MT7628 PHY!!!!!!
Please choose the operation:
gpio trigger enabled
GPIO 46 is low
You chose 3
0
Image Name: MIPS OpenWrt Linux-3.18.29
Data Size: 1146199 Bytes = 1.1 MB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
No initrd
Starting kernel ...
[ 0.000000] Linux version 3.18.29 (vocore@ubuntu) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r49378) ) #6 Sat May 27 17:23:12 CST 2017
[ 0.000000] Board has DDR2
[ 0.000000] Analog PMU set to hw control
[ 0.000000] Digital PMU set to hw control
[ 0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
[ 0.000000] MIPS: machine is VoCore2
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x07ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000-0x07ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000-0x07ffffff]
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS2,115200 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=0000000f
[ 0.000000] Readback ErrCtl register=0000000f
[ 0.000000] Memory: 126340K/131072K available (2530K kernel code, 131K rwdata, 520K rodata, 136K init, 186K bss, 4732K reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:256
[ 0.000000] intc: using register map from devicetree
[ 0.000000] CPU Clock: 580MHz
[ 0.000000] clocksource_of_init: no matching clocksources found
[ 0.000000] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216)
[ 0.060000] pid_max: default: 32768 minimum: 301
[ 0.060000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070000] pinctrl core: initialized pinctrl subsystem
[ 0.080000] NET: Registered protocol family 16
[ 0.100000] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.110000] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.120000] Switched to clocksource MIPS
[ 0.120000] NET: Registered protocol family 2
[ 0.130000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.130000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.140000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.140000] TCP: reno registered
[ 0.150000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.150000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.160000] NET: Registered protocol family 1
[ 0.170000] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.180000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.190000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.200000] msgmni has been set to 246
[ 0.210000] io scheduler noop registered
[ 0.210000] io scheduler deadline registered (default)
[ 0.220000] gdma-mt7628 10002800.gdma: revision: 3, channels: 16
[ 0.230000] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.230000] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[ 0.240000] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[ 0.250000] console [ttyS2] disabled
[ 0.260000] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[ 0.270000] console [ttyS2] enabled
[ 0.270000] bootconsole [early0] disabled
[ 0.280000] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.290000] m25p80 spi32766.0: found w25q128, expected en25q64
[ 0.300000] m25p80 spi32766.0: w25q128 (16384 Kbytes)
[ 0.300000] m25p80 spi32766.0: using chunked io
[ 0.310000] 4 ofpart partitions found on MTD device spi32766.0
[ 0.320000] Creating 4 MTD partitions on "spi32766.0":
[ 0.320000] 0x000000000000-0x000000030000 : "u-boot"
[ 0.330000] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.330000] 0x000000040000-0x000000050000 : "factory"
[ 0.340000] 0x000000050000-0x000001000000 : "firmware"
[ 0.410000] 2 uimage-fw partitions found on MTD device firmware
[ 0.410000] 0x000000050000-0x000000167d97 : "kernel"
[ 0.420000] 0x000000167d97-0x000001000000 : "rootfs"
[ 0.420000] mtd: device 5 (rootfs) set to be root filesystem
[ 0.430000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.440000] 0x000000690000-0x000001000000 : "rootfs_data"
[ 0.450000] ralink_soc_eth 10100000.ethernet: generated random MAC address d6:cb:e5:bd:f3:fd
[ 0.460000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
[ 0.470000] mt7621_wdt 10000120.watchdog: Initialized
[ 0.470000] TCP: cubic registered
[ 0.480000] NET: Registered protocol family 17
[ 0.480000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 0.500000] 8021q: 802.1Q VLAN Support v1.8
[ 0.520000] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 0.530000] Freeing unused kernel memory: 136K (8031e000 - 80340000)
[ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000] Freeing [ 0.520000] VFS: Mou[ 0.530000][ 2.330000] init: Console is alive
Freeing [ 0.[ 2.330000] ttyS2: 3 input overrun(s)
520000] VFS: [ 2.340000] init: - watchdog -
Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.530000][ 2 Freeing [ 0.[ 2.520000] VFS: [ 2.340Mou[ 0.5
Bootloader does not wait for the choice of 0-9, it immediately starts with 3
Re: Startup error
Sat Dec 30, 2017 9:11 am
This is a weird issue. Try to keep it in reset mode(touch RESET pin with GND), then connect its UART, then remove reset.
