SD card-Ethernet conflict
Posted: Thu Dec 28, 2017 9:42 pm
Greetings and happy holidays,
We are working on a project where 2 Ethernet ports of the Vocore2 and the SD card is required. We are using Ethernet ports 1 and 2.
It seems like the SD card is pinmuxed with Ethernet port 3 and 4, you can only enable or disable all of the 4 Ethernet ports 1,2,3,4 and these prevents us from using simultaneously the Ethernet ports 1 and 2 with the SD card.
Is this correct?
Is there any workaround/soloution so you can have 2 x Ethernet ports enabled along with the SD card?
Thanks in advance.
Evan
Is this correct?
Thanks in advance.
Evan
