Latest LEDE firmware slow/drop wifi connection
ICore
Sat Jan 13, 2018 11:27 pm
I recently did a factory reset of the device using the USB2TTL connection. I rebooted and did a firmware upgrade to the latest available today. Everything is as default, enabled wifi and did a reboot. No password, connecting to SSID LEDE works but wireless speeds are slow and the connection drops all the time, i have to refresh the LuCi page all the time to finish loading, configuration is almost impossible.
Can i install DD-WRT on Vocore2 Ultimate ?
thanks.
jperkins
Re: Latest LEDE firmware slow/drop wifi connection
Sun Jan 14, 2018 12:20 am
I'm new here but been reading the wifi issue relates to the driver used for wifi. LEDE uses the open source driver but vocore uses proprietary one.
the open source driver is not very good yet.
IDK maybe you are using the firmware from this post already ?
http://vonger.cn/?p=14366
Mon Jan 15, 2018 4:17 pm
It is usable but somehow not that friendly as openwrt.
You have to use iwpriv to config that driver but can not use uci.
We are working on the uci interface, but just new hand here, process is pretty slow :)
There is somebody make one patch: https://github.com/Nossiac/mtk-openwrt-feeds
You can replace mt7628.ko with mine, so it will work on latest LEDE Linux4.9, it should work with uci(most part)
Users browsing this forum: No registered users and 3 guests
