How to use Timer Interrupt
markus.vocore
Tue Apr 10, 2018 2:06 pm
Dear all,
I need a configurable timer for VoCore IoT device, e.g. with 10 ms to debounce buttons or with 100 ms to blink an LED. According to MT7628 datasheet, there are 2 hardware timer available: timer0 and timer1. I did some testings with timer0 and I was able to configure and start it (by using registers T0CTL_REG, T0LMT_REG and T0_REG).
Questions:
1. Why are IRQ INTC-24 (timer0) and INTC-25 (timer1) not showing up in /proc/interrupts?
2. How can I use the interrupts from my application, which is written in ANSI C and running in user space?
About question 2: I guess I have to write a kernel module, right? If so, does anybody know or have some examples or tutorials, how to write and compile those modules for VoCore / OpenWrt? This because I have no experience with kernel modules and I guess at some point I won't be able to avoid them anymore in my VoCore project.
Many thanks and regards,
Markus
> cat /proc/interrupts
           CPU0
  5:       6212      MIPS   5  10100000.ethernet
  6:     406049      MIPS   6  ra0
  7:    1730803      MIPS   7  timer
 15:          0      INTC   7  10002800.gdma
 25:          1      INTC  17  esw
 26:          1      INTC  18  ehci_hcd:usb1, ohci_hcd:usb2
 30:       1049      INTC  22  serial
ERR:          0
markus.vocore
Re: How to use Timer Interrupt
Wed Apr 11, 2018 2:08 pm
btw: This is the test script I've been using to test timer0:
#!/bin/bash
echo "Init timer0: PSC = 1000, T0EN/T0AL = 1, Limit = 10'000 -> Clock = 1 ms, Period = 10 s"
mem 0x10000110 0x03E80090
mem 0x10000114 0x00002710
sleep 1
echo "Timer is not showing up in interrupts... Why??"
while true; do
echo "Timer counter: "
mem 0x10000118
sleep 1
done
Tue Apr 17, 2018 2:42 am
I am afraid they are already taken by Linux kernel, you have to use linux kernel api.
Users browsing this forum: Google [Bot] and 36 guests
