Not booting if using UART1
Posted: Fri May 11, 2018 9:06 am
by markus.vocore
Hello
We are using 2x UART:
- UART2 (RXD2 / TXD2) for debugging console and for programming
- UART1 (RXD1 / TXD1) for communication with an IC
The VoCore2 is not booting anymore, if UART1 is connected. See console output below. What is happening here and what can I do to use UART1?
Thanks!
Markus
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
RESET MT7628 PHY!!!!!!
Please choose the operation:
gpio trigger enabled
GPIO 46 is high
10 release GPIO 46 now for web load
10 release GPIO 46 now for usb load
10 too late
Re: Not booting if using UART1
Posted: Sat May 12, 2018 2:49 am
Please use this uboot(you can change uboot by select 7 at start up)
http://vonger.cn/misc/vocore2/uboot.20180427.bin
Posted: Mon May 14, 2018 12:17 pm
by markus.vocore
Works perfect, thank you!
