SD + SPI LCD on vocore 2?
xcutc
Tue Jun 05, 2018 4:08 pm
hello,
i would like to use this board for a badge project.
my plan is to connect a µSD and a 2.8" SPI display (ILI9341).
i would like to use the fbtft driver, i'm curious if that will work, did someone something like this before?
greetingsa
Re: SD + SPI LCD on vocore 2?
Thu Jun 07, 2018 12:14 am
Please check http://vonger.cn/?p=8216, there are five blog about use SPI screen.
If use fbtft, you will need to hack the kernel a little. :) good luck.
xcutc
Thu Jun 07, 2018 6:41 am
interesting, thanks!
is the speed a limitation from the vocore or the lcd that u used?
if its the vocore, it will be useless for my application.... :(
Fri Jun 08, 2018 3:16 am
it is spi screen...vocore spi max speed is at least 10Mbps, but normally screen with spi interface only support 2Mbps at most.
Do you check my new invention :p ==> vocore2 screen(http://vocore.io/screen.html)? it is go over USB port, speed is no problem, up to 25fps 800x480 at 24bit true color.
Users browsing this forum: No registered users and 181 guests
