I would like to increase the Wifi Signal Range of my Vocore2 unit in AP Mode and need some advice.
Can I simply add an external antenna to the U.FL connector and then enable the port by running the script "sh /tmp/ant2.sh".
Can the onboard antenna be replaced with a U.FL connector for 2 external antennas?
Thanks
Multiple Antennas for longer range?
- eaglecbr
Re: Multiple Antennas for longer range?
Yes, if you want to longer range, you can remove onboard antenna and solder new U.FL to it, and also you can use ant2.sh to enable two of them.
