Multiple Antennas for longer range?
Posted: Sun Jun 24, 2018 12:33 pm
by eaglecbr
I would like to increase the Wifi Signal Range of my Vocore2 unit in AP Mode and need some advice.
Can I simply add an external antenna to the U.FL connector and then enable the port by running the script "sh /tmp/ant2.sh".
Can the onboard antenna be replaced with a U.FL connector for 2 external antennas?
Thanks
Re: Multiple Antennas for longer range?
Posted: Mon Jun 25, 2018 9:48 am
Yes, if you want to longer range, you can remove onboard antenna and solder new U.FL to it, and also you can use ant2.sh to enable two of them.
