I want to ask is possible to set default states for gpio ports, i need to do this because i have custom board for vocore which have connections to external circuits. after vocore boots i set all gpio as i need it, but during boot process there is some problems because ports default configuration, is it possible to do this ? i made a little research and i suspect that i need to do this in device tree file(.dts), am i right, can anyone maybe have some example, how to do this on vocore?
Greetings
setting default options for i/o ports
- kermit
Re: setting default options for i/o ports
This have to be done in bootloader.
Please check github.com/vonger and get the bootloader source code, add register control for gpio default value, that's the most simple way.
Users browsing this forum: No registered users and 67 guests
