AP + STA mode - can't communicate between clients
dimitry
Mon Sep 10, 2018 2:14 pm
VoCore 2 is running in AP + STA mode. Connect to it with 2 clients. Both get DHCP addresses. Both can access internet. Tried SSH'ing from one client to the other - no connection. Tried pinging - no cigar. What to do?
Re: AP + STA mode - can't communicate between clients
Wed Sep 12, 2018 2:14 pm
check firewall, allow forward mode :)
dimitry
Wed Sep 12, 2018 3:06 pm
How can I tell if it's enabled? Here is my firewall config:
firewall.@defaults[0]=defaults
firewall.@defaults[0].syn_flood='1'
firewall.@defaults[0].input='ACCEPT'
firewall.@defaults[0].output='ACCEPT'
firewall.@defaults[0].forward='REJECT'
firewall.@zone[0]=zone
firewall.@zone[0].name='lan'
firewall.@zone[0].network='lan'
firewall.@zone[0].input='ACCEPT'
firewall.@zone[0].output='ACCEPT'
firewall.@zone[0].forward='ACCEPT'
firewall.@zone[1]=zone
firewall.@zone[1].name='wan'
firewall.@zone[1].network='wan' 'wan6' 'wwan'
firewall.@zone[1].output='ACCEPT'
firewall.@zone[1].masq='1'
firewall.@zone[1].mtu_fix='1'
firewall.@zone[1].input='ACCEPT'
firewall.@zone[1].forward='ACCEPT'
firewall.@forwarding[0]=forwarding
firewall.@forwarding[0].src='lan'
firewall.@forwarding[0].dest='wan'
firewall.@rule[0]=rule
firewall.@rule[0].name='Allow-DHCP-Renew'
firewall.@rule[0].src='wan'
firewall.@rule[0].proto='udp'
firewall.@rule[0].dest_port='68'
firewall.@rule[0].target='ACCEPT'
firewall.@rule[0].family='ipv4'
firewall.@rule[1]=rule
firewall.@rule[1].name='Allow-Ping'
firewall.@rule[1].src='wan'
firewall.@rule[1].proto='icmp'
firewall.@rule[1].icmp_type='echo-request'
firewall.@rule[1].family='ipv4'
firewall.@rule[1].target='ACCEPT'
firewall.@rule[2]=rule
firewall.@rule[2].name='Allow-IGMP'
firewall.@rule[2].src='wan'
firewall.@rule[2].proto='igmp'
firewall.@rule[2].family='ipv4'
firewall.@rule[2].target='ACCEPT'
firewall.@rule[3]=rule
firewall.@rule[3].name='Allow-DHCPv6'
firewall.@rule[3].src='wan'
firewall.@rule[3].proto='udp'
firewall.@rule[3].src_ip='fe80::/10'
firewall.@rule[3].src_port='547'
firewall.@rule[3].dest_ip='fe80::/10'
firewall.@rule[3].dest_port='546'
firewall.@rule[3].family='ipv6'
firewall.@rule[3].target='ACCEPT'
firewall.@rule[4]=rule
firewall.@rule[4].name='Allow-MLD'
firewall.@rule[4].src='wan'
firewall.@rule[4].proto='icmp'
firewall.@rule[4].src_ip='fe80::/10'
firewall.@rule[4].icmp_type='130/0' '131/0' '132/0' '143/0'
firewall.@rule[4].family='ipv6'
firewall.@rule[4].target='ACCEPT'
firewall.@rule[5]=rule
firewall.@rule[5].name='Allow-ICMPv6-Input'
firewall.@rule[5].src='wan'
firewall.@rule[5].proto='icmp'
firewall.@rule[5].icmp_type='echo-request' 'echo-reply' 'destination-unreachable' 'packet-too-big' 'time-exceeded' 'bad-header' 'unknown-header-type' 'router-solicitation' 'neighbour-solicitation' 'router-advertisement' 'neighbour-advertisement'
firewall.@rule[5].limit='1000/sec'
firewall.@rule[5].family='ipv6'
firewall.@rule[5].target='ACCEPT'
firewall.@rule[6]=rule
firewall.@rule[6].name='Allow-ICMPv6-Forward'
firewall.@rule[6].src='wan'
firewall.@rule[6].dest='*'
firewall.@rule[6].proto='icmp'
firewall.@rule[6].icmp_type='echo-request' 'echo-reply' 'destination-unreachable' 'packet-too-big' 'time-exceeded' 'bad-header' 'unknown-header-type'
firewall.@rule[6].limit='1000/sec'
firewall.@rule[6].family='ipv6'
firewall.@rule[6].target='ACCEPT'
firewall.@include[0]=include
firewall.@include[0].path='/etc/firewall.user'
firewall.@rule[7]=rule
firewall.@rule[7].src='wan'
firewall.@rule[7].dest='lan'
firewall.@rule[7].proto='esp'
firewall.@rule[7].target='ACCEPT'
firewall.@rule[8]=rule
firewall.@rule[8].src='wan'
firewall.@rule[8].dest='lan'
firewall.@rule[8].dest_port='500'
firewall.@rule[8].proto='udp'
firewall.@rule[8].target='ACCEPT'
dimitry
Wed Sep 12, 2018 3:22 pm
My wireless configuration is:
wireless.ap.device='radio0'
wireless.ap.mode='ap'
wireless.ap.network='lan'
wireless.ap.ifname='ra0'
wireless.ap.ssid='internal'
wireless.ap.key='password'
wireless.ap.encryption='psk'
Both clients connect to VoCore on the same 'internal' wifi. Both get DHCP in the same range 192.168.61.X. So, they should both be in the same 'lan' zone. No forwarding should be necessary if I understand it correctly.
dimitry
Wed Sep 12, 2018 7:42 pm
Updated to firmware 20180723V.bin and it's still not working
dimitry
Wed Sep 12, 2018 8:00 pm
Tried adding forwarding to the firewall:
lan -> lan
wan -> lan
(lan -> wan is already enabled)
Hairpinning is also enabled:
root@OpenWrt:~# cat /sys/devices/virtual/net/br-lan/lower_ra0/brport/hairpin_mode
1
root@OpenWrt:~# cat /sys/devices/virtual/net/br-lan/lower_ra0/brport/multicast_to_unicast
1
dimitry
Fri Sep 14, 2018 12:13 am
Nobody else has this problem? Vonger, you there?
dimitry
Mon Sep 17, 2018 9:44 pm
Hi Vonger, Could you please provide further directions? I don't know what to do at this point. Thank you.
Tue Sep 18, 2018 9:20 am
I have no idea now, this should be simple...
If all you device can access VoCore2, the only problem block them communicate each other is firewall.
Try to change every REJECT to ACCEPT
Users browsing this forum: No registered users and 65 guests
