Unable to bootm current OpenWRT image
overzelus
Sat Sep 29, 2018 4:39 am
Instead of risking a failed upgrade, I've been attempting to use u-boot to load an image over kermit and use the bootm to test.
Per this post, it's not going well.
I've been using a fresh git clone of the OpenWRT repository and a Kubuntu 18.04 host system.
I think I've managed to satisfy OpenWRT's library requirements, and the image appears to build successfully.
I copy:
/home/zelus/openwrt/bin/targets/ramips/mt76x8/openwrt-ramips-mt76x8-vocore2-squashfs-sysupgrade.bin
to the Vocore2 (no dock) and attempt to bootm.
This is what happens:
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
Date:Jun 25 2016  Time:22:54:33
RESET MT7628 PHY!!!!!!
Please choose the operation:
gpio trigger enabled
GPIO 46 is low
 8
You chose 4
 0
4: System Enter Boot Command Line Interface.
U-Boot 1.1.3 (Jun 25 2016 - 22:54:33)
VoCore2 > loadb
## Ready for binary (kermit) download to 0x80100000 at 115200 bps...
(Back at Gemini)
(/home/zelus/) C-Kermit>send ~/boot.bin
(/home/zelus/) C-Kermit>connect
Connecting to /dev/ttyUSB0, speed 115200
## Total Size      = 0x003802c1 = 3670721 Bytes
## Start Addr      = 0x80100000
VoCore2 > bootm
## Booting image at 80100000 ...
   Image Name:   MIPS OpenWrt Linux-4.14.71
   Image Type:   MIPS Linux Kernel Image (lzma compressed)
   Data Size:    1542756 Bytes =  1.5 MB
   Load Address: 80000000
   Entry Point:  80000000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... LZMA ERROR 1 - must RESET board to recover
Am I doing anything obviously wrong? Do I really need to use a 14.04 VM to work with this code?
overzelus
Re: Unable to bootm current OpenWRT image
Mon Oct 01, 2018 12:13 am
After a few experiments, I realize this image apparently isn't in a format that's capable of being bootm'd.
Still trying to understand OpenWRT's fairly unique filesystem layout along with the boot architecture and build environment.
Knowing that I can use u-boot option 0 and the 20170527V.bin image to recover after a weird update has been enough to allow me to continue forward.
Wed Oct 03, 2018 9:10 am
mediatek uboot you need to setting up some env about file size...
please check its source code at github.com/vonger/
Users browsing this forum: Bing [Bot] and 7 guests
