Unable to bootm current OpenWRT image
Posted: Sat Sep 29, 2018 4:39 am
Instead of risking a failed upgrade, I've been attempting to use u-boot to load an image over kermit and use the bootm to test.
Per this post, it's not going well.
I've been using a fresh git clone of the OpenWRT repository and a Kubuntu 18.04 host system.
I think I've managed to satisfy OpenWRT's library requirements, and the image appears to build successfully.
I copy:
/home/zelus/openwrt/bin/targets/ramips/mt76x8/openwrt-ramips-mt76x8-vocore2-squashfs-sysupgrade.bin
to the Vocore2 (no dock) and attempt to bootm.
This is what happens:
Am I doing anything obviously wrong? Do I really need to use a 14.04 VM to work with this code?
I copy:
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
RESET MT7628 PHY!!!!!!
Please choose the operation:
gpio trigger enabled
GPIO 46 is low
8
You chose 4
0
4: System Enter Boot Command Line Interface.
U-Boot 1.1.3 (Jun 25 2016 - 22:54:33)
VoCore2 > loadb
## Ready for binary (kermit) download to 0x80100000 at 115200 bps...
(Back at Gemini)
(/home/zelus/) C-Kermit>send ~/boot.bin
(/home/zelus/) C-Kermit>connect
Connecting to /dev/ttyUSB0, speed 115200
## Total Size = 0x003802c1 = 3670721 Bytes
## Start Addr = 0x80100000
VoCore2 > bootm
## Booting image at 80100000 ...
Image Name: MIPS OpenWrt Linux-4.14.71
Data Size: 1542756 Bytes = 1.5 MB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
Uncompressing Kernel Image ... LZMA ERROR 1 - must RESET board to recover
