18.06.2 Fails to build
- victorbr
Re: 18.06.2 Fails to build
Hi everyone, do you know if its possible to install ubuntu on vocore2 and run tomcat and mysql? if its possible, do you have a tutorial or informatio to achieve that task? Thanks in advance
It is not possible, vocore2 do not have enough memory for them.
But you can use openwrt replace ubuntu and use sqlite3 replace mysql.
Same function.
Same function.
- fmm
Hello World!
It seems that I have the same error.
I've seen that could be avoided by building the kernel and after that we copy the patches, but does that make sense?
make[4]: Entering directory '/home/fm/openwrt/build_dir/target-mipsel_24kc_musl/hostapd-full-internal/hostapd-2018-05-21-62566bc2/hostapd'
../src/ap/sta_info.o: In function `ap_sta_add':
sta_info.c:(.text.ap_sta_add+0x12e): undefined reference to `[b]sta_track_claim_taxonomy_info[/b]'
collect2: error: ld returned 1 exit status
Makefile:1298: recipe for target 'hostapd' failed
make[4]: *** [hostapd] Error 1
make[4]: Leaving directory '/home/fm/openwrt/build_dir/target-mipsel_24kc_musl/hostapd-full-internal/hostapd-2018-05-21-62566bc2/hostapd'
Makefile:577: recipe for target '/home/fm/openwrt/build_dir/target-mipsel_24kc_musl/hostapd-full-internal/hostapd-2018-05-21-62566bc2/.built' failed
make[3]: *** [/home/fm/openwrt/build_dir/target-mipsel_24kc_musl/hostapd-full-internal/hostapd-2018-05-21-62566bc2/.built] Error 2
make[3]: Leaving directory '/home/fm/openwrt/package/network/services/hostapd'
time: package/network/services/hostapd/full-internal/compile#0.51#0.12#1.00
package/Makefile:111: recipe for target 'package/network/services/hostapd/compile' failed
make[2]: *** [package/network/services/hostapd/compile] Error 2
make[2]: Leaving directory '/home/fm/openwrt'
package/Makefile:107: recipe for target '/home/fm/openwrt/staging_dir/target-mipsel_24kc_musl/stamp/.package_compile' failed
make[1]: *** [/home/fm/openwrt/staging_dir/target-mipsel_24kc_musl/stamp/.package_compile] Error 2
make[1]: Leaving directory '/home/fm/openwrt'
/home/fm/openwrt/include/toplevel.mk:216: recipe for target 'world' failed
make: *** [world] Error 2
- fmm
SOLVED!
https://github.com/vonger/vocore2
In step 3:
Instead of "make menuconfig" and modifying the stock .config,
I did "cp ./package/vocore2/.config ./", and then modified the customized .config, and then I did make it.
Yes another error came up, but at least that was solved
In step 3:
vondess wrote:I built but it took me 2 trys to follow the directions exactly.
If the tutorial has mistake blocks you build it please let me know
Users browsing this forum: No registered users and 6 guests
