The tests for WiFi FCC certification require that the WiFi module be placed in continuous transmission at a fixed frequency.
Is there any way to get this with the Vocore2?
- glbaldini
Re: WiFi FCC certification
Yes, this require your wifi driver support it.
We already have FCC.
- glbaldini
The wifi driver is the standard one, included in the image of Vocore2 that we have downoloaded.
Can you please tell me which is the command od the procedure to set the WiFi in fixed frequency transmission?
Thank you
Thank you
VoCore2 already has FCCID, please directly use it, you do not need to setting it.
- glbaldini
Thank you, I'll try using the existing FCC certificate.
I see that there's also a CE certificate, but it is related to the old R&TTE directive.
Is there a certificate according to the new RED directive?
CE RED need to do with production. so we do not have that.
And in the wifi driver source code there is a help documentation.
- dieguz
Vonger wrote:CE RED need to do with production. so we do not have that.
Hi, I need these indications too, in which path of openwrt sources I find the wifi driver source with the indications?
Thanks!
it is in mt7628 source code, src/embedded/doc, check iwpriv_usage.txt and ate_iwpriv_usage.txt
If it is not easy to understand, please email to our support@vocore.io, we can send you the test process of the FCC cert, might help you do you CE.
- dieguz
Vonger wrote:it is in mt7628 source code, src/embedded/doc, check iwpriv_usage.txt and ate_iwpriv_usage.txt
Hi, I tried to send you a reply email to support@vocore.io but the mail is not delivered, the error is : 550 Domain frequency limited.
How can I contact You ?
that is weird...please try to email to tasie@vocore.io
Users browsing this forum: Google [Bot] and 1 guest
