I am backed the Vocore2 Ultimate.
Recently, I updated Vocore2 to the latest firmware and connect to Vocore´s wifi but cannot find anything. It keep scanning and does not show any result. I wonder if anyone can help me.
After fixing it, I would like to have Vocore2 function similar to TP-Link´s WISP mode. Meaning: Connect to a hotspot and broadcast another wifi for multiple devices; the hotspot only see 1 IP.
The problem is Unitymedia require a custom certificate https://www.unitymedia.de/content/dam/dcomm-unitymedia-de/Privatkunden/angebote/wifispot/LGI_Root_CA.cer
and also specific EAP, Authentication.
I found a guide here:
https://datafreak.eu/2018/09/unitymedia ... ls-client/
But I have no idea how to apply to Vocore2.
I would be grateful if you can help me. I don´t have electronics/networks knowledge so more details guide would be nice.
In case Vocore cannot handle 2 wifi signal , connect to hotspot then relay to LAN is OK as well.
Thankyou and best regards,
[2 Issues] Cannot scan for wifi; Vocore2 as WISP
- T-virus
Re: [2 Issues] Cannot scan for wifi; Vocore2 as WISP
Which firmware you are using?
Please use the latest firmware from vocore.io/v2 but not openwrt.
openwrt one default wifi is off, so you can not find any ap anymore.
vocore.io/v2 one (in firmware section, normally uses a date code as its version) default enable wifi and optimize many options for easy using.
