I saw you were able to manage to build a PoE version.
This is great news to me, since I basically use a vocore2 ultimate as an OpenVPN server (and as such I just need the ethernet).
I would just plug this into my PoE capable switch and use the ultimate elsewhere.
To avoid any unneded discharge I would put it into a case, assuming the temperature in a closed case is manageable.
1) is there a case available?
2) are the ultimate case STL avail so we can remove the excess holes, and print it?
Thank you
m.
vocore2 + PoE Case
- murraythegoz
- murraythegoz
Re: vocore2 + PoE Case
Any update on this?
can you make the STL of the ultimate case avail?
So we can at least build one ourselves, just need to arrange the holes.
Thank you
m.
Thank you
m.
VoCore2 Ultimate shell can download here: http://vonger.cn/misc/vocore2/vocore2f.box.stl
But PoE has different port position
Users browsing this forum: Bing [Bot] and 5 guests
