vocore2 + PoE Case
Posted: Thu Sep 19, 2019 4:08 pm
I saw you were able to manage to build a PoE version.
This is great news to me, since I basically use a vocore2 ultimate as an OpenVPN server (and as such I just need the ethernet).
I would just plug this into my PoE capable switch and use the ultimate elsewhere.
To avoid any unneded discharge I would put it into a case, assuming the temperature in a closed case is manageable.
1) is there a case available?
2) are the ultimate case STL avail so we can remove the excess holes, and print it?
Thank you
m.
Thank you
m.
