Ethernet can't work, help to find what's wrong
Drew
Mon Nov 25, 2019 11:10 pm
I have vocore light and I bougth rj45 socket with transformators, KLS12-TL002R-1*1-G/Y-1-03
below is schem.
https://documentcloud.adobe.com/link/tr ... 569068e0b3
I found vocore dock schem., so I connected it to vocore:
Socket pins <-> vocore pins
3 <->porp(33)
6 <->porn(34)
1 <->potp(35)
2 <->potn(36)
Also, as it is on dock diagram 4 and 5 socket pin's connected to +1,8v
Is it enough? Because, I have no connection with my ordinary router's lan port and wan interface of vocore.
Maybe I have to change some registers or something else...
Thank's for any advice.
Re: Ethernet can't work, help to find what's wrong
Tue Nov 26, 2019 4:21 am
ethernet should be 1,2,3,5
4,6 as I know it should connect to 100nF then GND, do not need to connect to 1.8V. and connect wire need to be very short, for my test, if wire long than 3cm will cost data transfer has problem.
check vocore.io/v2u.html, source part, dock sch.
Users browsing this forum: No registered users and 57 guests
