Installed a Package Using (–force-depends), Then Got Stuck
fmm
Wed Dec 04, 2019 6:24 pm
Hello gents,
I'm using VoCore2 running OpenWrt, and I did install a package this way:
kmod install kmod-usb-net --force-depends
After that the rebooting never ends :blush:
Thanks in advance and here is the terminal output:
U-Boot 1.1.3 (Aug 21 2018 - 23:55:37)
Board: Ralink APSoC DRAM:  128 MB
relocate_code Pointer at: 87fb8000
flash manufacture id: c8, device id 40 18
find flash: GD25Q128C
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
Date:Aug 21 2018  Time:23:55:37
 ##### The CPU freq = 575 MHZ ####
 estimate memory size =128 Mbytes
RESET MT7628 PHY!!!!!!
Please choose the operation:
   0: Load system code then write to Flash via Serial.
   9: Load Boot Loader code then write to Flash via TFTP.                     0
   Image Name:   MIPS OpenWrt Linux-4.14.131
   Data Size:    1497367 Bytes =  1.4 MB
   Load Address: 80000000
   Entry Point:  80000000
   Verifying Checksum ... OK
No initrd
Starting kernel ...
[    0.000000] Linux version 4.14.131 (user@user) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 r7808-ef686b7292)) #0 Thu Jun 27 12:18:52 2019
[    0.000000] Board has DDR2
[    0.000000] Analog PMU set to hw control
[    0.000000] Digital PMU set to hw control
[    0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
[    0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
[    0.000000] MIPS: machine is VoCore2
[    0.000000]  memory: 08000000 @ 00000000 (usable)
[    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] random: get_random_bytes called from start_kernel+0x90/0x478 with crng_init=0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 32512
[    0.000000] Kernel command line: console=ttyS2,115200 console=tty0 fbcon=rotate:3 rootfstype=squashfs,jffs2
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Writing ErrCtl register=000339fe
[    0.000000] Readback ErrCtl register=000339fe
[    0.000000] Memory: 124956K/131072K available (3466K kernel code, 178K rwdata, 832K rodata, 188K init, 201K bss, 6116K reserved, 0K cma-reserved)
[    0.000000] NR_IRQS: 256
[    0.000000] intc: using register map from devicetree
[    0.000000] CPU Clock: 580MHz
[    0.000000] timer_probe: no matching timers found
[    0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6590553264 ns
[    0.000012] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns
[    0.007541] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216)
[    0.073503] pid_max: default: 32768 minimum: 301
[    0.078201] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.084551] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.096916] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.106408] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.112362] pinctrl core: initialized pinctrl subsystem
[    0.117949] NET: Registered protocol family 16
[    0.148566] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.154156] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.159757] mt7621_gpio 10000600.gpio: registering 32 gpios
[    0.169440] clocksource: Switched to clocksource MIPS
[    0.175521] NET: Registered protocol family 2
[    0.180702] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.187396] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.193580] TCP: Hash tables configured (established 1024 bind 1024)
[    0.199827] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.205430] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.211784] NET: Registered protocol family 1
[    0.219333] Crashlog allocated RAM at address 0x3f00000
[    0.226199] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    0.238335] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.243957] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.263651] io scheduler noop registered
[    0.267385] io scheduler deadline registered (default)
[    0.273283] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[    0.280691] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[    0.290051] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[    0.299068] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[    0.699620] console [ttyS2] enabled
[    0.707259] cacheinfo: Failed to find cpu0 device node
[    0.717706] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.730795] spi-mt7621 10000b00.spi: sys_freq: 193333333
[    0.745952] m25p80 spi0.0: gd25q128 (16384 Kbytes)
[    0.755784] 4 fixed-partitions partitions found on MTD device spi0.0
[    0.768663] Creating 4 MTD partitions on "spi0.0":
[    0.778381] 0x000000000000-0x000000030000 : "u-boot"
[    0.789368] 0x000000030000-0x000000040000 : "u-boot-env"
[    0.801071] 0x000000040000-0x000000050000 : "factory"
[    0.812213] 0x000000050000-0x000001000000 : "firmware"
[    0.894733] 2 uimage-fw partitions found on MTD device firmware
[    0.906766] 0x000000050000-0x0000001bd957 : "kernel"
[    0.917726] 0x0000001bd957-0x000001000000 : "rootfs"
[    0.928668] mtd: device 5 (rootfs) set to be root filesystem
[    0.941709] 1 squashfs-split partitions found on MTD device rootfs
[    0.954298] 0x000000580000-0x000001000000 : "rootfs_data"
[    0.966912] libphy: Fixed MDIO Bus: probed
[    0.986635] rt3050-esw 10110000.esw: link changed 0x00
[    0.998731] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[    1.017321] NET: Registered protocol family 10
[    1.030542] Segment Routing with IPv6
[    1.038083] NET: Registered protocol family 17
[    1.047201] 8021q: 802.1Q VLAN Support v1.8
[    1.067402] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[    1.082788] Freeing unused kernel memory: 188K
[    1.091815] This architecture does not have kernel memory protection.
[    2.238108] init: Console is alive
[    2.245325] init: - watchdog -
[    2.429449] random: fast init done
[    4.074142] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    4.216538] usbcore: registered new interface driver usbfs
[    4.227828] usbcore: registered new interface driver hub
[    4.238721] usbcore: registered new device driver usb
[    4.254772] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.269959] ehci-platform: EHCI generic platform driver
[    4.290897] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[    4.304486] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[    4.315091] ehci-platform 101c0000.ehci: EHCI Host Controller
[    4.326772] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[    4.342953] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[    4.379456] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[    4.393172] hub 1-0:1.0: USB hub found
[    4.401215] hub 1-0:1.0: 1 port detected
[    4.412713] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.427057] ohci-platform: OHCI generic platform driver
[    4.438000] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[    4.451820] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[    4.467981] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[    4.554445] hub 2-0:1.0: USB hub found
[    4.562490] hub 2-0:1.0: 1 port detected
[    4.583537] MTK MSDC device init.
[    4.649668] mtk-sd: MediaTek MT6575 MSDC Driver
[    4.666162] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    4.691424] init: - preinit -
[    5.967329] rt3050-esw 10110000.esw: link changed 0x00
[    6.271330] random: procd: uninitialized urandom read (4 bytes read)
[    9.690390] jffs2: notice: (383) jffs2_build_xattr_subsystem: complete building xattr subsystem, 29 of xdatum (2 unchecked, 27 orphan) and 44 of xref (27 dead, 0 orphan) found.
[    9.725975] mount_root: switching to jffs2 overlay
[    9.774347] overlayfs: upper fs does not support tmpfile.
[    9.799307] urandom-seed: Seeding with /etc/urandom.seed
[   10.004010] procd: - early -
[   10.010043] procd: - watchdog -
[   10.704359] procd: - watchdog -
[   10.711069] procd: - ubus -
[   10.859343] random: ubusd: uninitialized urandom read (4 bytes read)
[   11.022659] random: ubusd: uninitialized urandom read (4 bytes read)
[   11.036129] random: ubusd: uninitialized urandom read (4 bytes read)
[   11.050135] procd: - init -
[   11.452684] kmodloader: loading kernel modules from /etc/modules.d/*
[   11.500745] CPU 0 Unable to handle kernel paging request at virtual address 0000000c, epc == 80070c68, ra == 80070a90
[   11.522317] Oops[#1]:
[   11.526915] CPU: 0 PID: 465 Comm: kmodloader Not tainted 4.14.131 #0
[   11.539782] task: 87d0c000 task.stack: 87626000
[   11.548946] $ 0   : 00000000 00000001 00000000 8761b268
[   11.559530] $ 4   : 80450e98 00000000 8761b12c ffff8000
[   11.570115] $ 8   : ffffc000 fffffffc 00000020 00000114
[   11.580698] $12   : 00000001 00000000 00000004 65646f6d
[   11.591280] $16   : 8761b120 87627ec0 00000000 8761b12c
[   11.601863] $20   : 8761b168 80450000 fffffff8 80450000
[   11.612447] $24   : 00000000 00000000
[   11.623031] $28   : 87626000 87627dd8 00000000 80070a90
[   11.633617] Hi    : 0000000e
[   11.639433] Lo    : 00000000
[   11.645279] epc   : 80070c68 load_module+0x1ab4/0x1dc8
[   11.655682] ra    : 80070a90 load_module+0x18dc/0x1dc8
[   11.666077] Status: 1100a403 KERNEL EXL IE
[   11.674551] Cause : 00800008 (ExcCode 02)
[   11.682657] BadVA : 0000000c
[   11.688477] PrId  : 00019655 (MIPS 24KEc)
[   11.696582] Modules linked in: mii(+) sha256_generic sha1_generic jitterentropy_rng drbg md5 hmac echainiv des_generic deflate zlib_inflate zlib_deflate cbc authenc crypto_acompress mmc_block mtk_sd mmc_core leds_gpio ohci_platform ohci_hcd ehci_platform ehci_hcd gpio_button_hotplug usbcore nls_base usb_common aead cryptomgr crypto_null crypto_hash
[   11.759204] Process kmodloader (pid: 465, threadinfo=87626000, task=87d0c000, tls=77fc8dc0)
[   11.776112] Stack : 8745dc80 014002c2 00000000 00000000 8761b12c 00007fff 8761b120 8006e5c4
[   11.793045]         803671f0 80450000 c01b68f4 ffffffff 8761b268 87457000 00402374 80440000
[   11.809978]         803ecf58 803f0000 80450000 80450e80 fffcd000 014002c0 8761afa0 0000000a
[   11.826910]         00000000 00000000 00000000 00000000 6e72656b 00006c65 77fbd000 77fbd000
[   11.843840]         00000000 800be2f4 878ea5b8 00000101 00000002 00000134 014002c0 000007cf
[   11.860772]         ...
[   11.860772]         ...
[   11.865714] Call Trace:
[   11.870660] [<80070c68>] load_module+0x1ab4/0x1dc8
[   11.880365] [<800710cc>] SyS_init_module+0x150/0x158
[   11.890425] [<800134ec>] syscall_common+0x34/0x58
[   11.899947] Code: 8fbf00d4  0c009331  00000000 <8ec20014> 02802825  0c04b4a4  8c440088  1440ff8c  00409025
[   11.919710]
[   11.919710]
[   11.922762] ---[ end trace 78e7fa44f8babf35 ]---
[   11.933946] Kernel panic - not syncing: Fatal exception
[   11.945559] Rebooting in 1 seconds..
[05000C0C][05000C09]
DDR Calibration DQS reg = 0000888A
Re: Installed a Package Using (–force-depends), Then Got Stu
Wed Dec 04, 2019 9:41 pm
maybe it is because linux kernel secure do not allow install kernel module in that way.
have to compile from source code, check github.com/vonger/vocore2
and to fix it, you need to use teraterm, update from uboot. check vocore.io/v2.html, "Fix bricked"
fmm
Thu Dec 05, 2019 2:23 pm
After seeing (## Ready for binary (kermit) download to 0x80100000 at 115200 bps...)
I sent the binary (Firmware(64MB+128MB, 20190802) using RealTerm, but nothing happened after that!
Did I sent it the correct way? is it the correct binary? did I miss something?
(While uploading the binary)
Fri Dec 06, 2019 2:29 am
Check vocore.io/v2.html, I can success download by using teraterm. teraterm File -> Send -> Kermit that way works well, and it will show a progress bar.
Also once I write a tool, I will update my blog later, you can use the command tool send file by kermit.
Update: http://vonger.cn/?p=14864
fmm
Sun Dec 08, 2019 12:48 pm
Kermit :geek:
I was trying to upload the FW using PuTTY and RealTerm but it seems that they didn't use the Kermit protocol, that's why.
Many thanks it works now :D
Users browsing this forum: No registered users and 30 guests
