Adding New Interface to (/etc/config/network) Doesn't Work!
Posted: Wed Jan 01, 2020 8:42 am
Hello World,
This was added to (/etc/config/network):
config interface 'usb_wan'
option ifname 'eth2'
option proto 'dhcp'
Then I run: /etc/init.d/network reload
I also tried: service network restart
but still the interface was not added, and my ifconfig shows:
Why?
option proto 'dhcp'
apcli0 Link encap:Ethernet HWaddr BA:D8:12:01:86:44
inet6 addr: fe80::b8d8:12ff:fe01:8644/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
br-lan Link encap:Ethernet HWaddr B8:D8:12:61:86:45
inet addr:192.168.2.1 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fda0:6ca4:618f::1/60 Scope:Global
inet6 addr: fe80::bad8:12ff:fe61:8645/64 Scope:Link
TX packets:16 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:2144 (2.0 KiB)
eth0 Link encap:Ethernet HWaddr B8:D8:12:61:86:45
TX packets:54 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:7909 (7.7 KiB)
Interrupt:5
eth0.1 Link encap:Ethernet HWaddr B8:D8:12:61:86:45
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:352 errors:0 dropped:0 overruns:0 frame:0
TX packets:352 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:23936 (23.3 KiB) TX bytes:23936 (23.3 KiB)
ra0 Link encap:Ethernet HWaddr B8:D8:12:61:86:44
inet6 addr: fe80::bad8:12ff:fe61:8644/64 Scope:Link
Interrupt:6
Why?
