VoCore MicroSD Slot
tschui
VoCore MicroSD Slot
Sat Jul 04, 2020 2:34 pm
Dear all,
I have a VoCore2 + USB & MicroSD Slot, and trying to mount a micro sd card.
With
 fidsk -l
command, I see:
Disk /dev/mmcblk0: 119.1 GiB, 127865454592 bytes, 249737216 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
I can also format the card into ext4 by using the
mkfs.ext4 /dev/mmcblk0
command,
all works fine.
Now when I enter
mount /dev/mmcblk0p1 /overlay
, I can't come past this error:
mount: mounting /dev/mmcblk0p1 on /overlay failed: Invalid argument
Also tried to mount on other folders as /root/mnt, but with the same error.
Is it a problem of the large SD card size?
Re: VoCore MicroSD Slot
Sun Jul 05, 2020 2:26 pm
I do not have that big SD card for test :) maybe you can try a small one?
and make sure the firmware has ext4 driver installed, sometimes if no driver or broken it will show that error.
Sun Jul 05, 2020 4:13 pm
Also check this link might help: http://vonger.cn/?p=14947
tschui
Thu Jul 09, 2020 3:37 pm
Thanks Vonger,
the ext4 driver was missing. I somehow thought I already had it :roll:
Keep up the good work!
Users browsing this forum: Google [Bot] and 50 guests
