VoCore MicroSD Slot
Posted: Sat Jul 04, 2020 2:34 pm
Dear all,
I have a VoCore2 + USB & MicroSD Slot, and trying to mount a micro sd card.
With
I can also format the card into ext4 by using the
all works fine.
Now when I enter
Also tried to mount on other folders as /root/mnt, but with the same error.
Is it a problem of the large SD card size?
With
fidsk -l
Disk /dev/mmcblk0: 119.1 GiB, 127865454592 bytes, 249737216 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
mkfs.ext4 /dev/mmcblk0
all works fine.
Now when I enter
mount /dev/mmcblk0p1 /overlay
mount: mounting /dev/mmcblk0p1 on /overlay failed: Invalid argument
