Wow, now 19.07.4 already supported that patch, but I tested the official compiled version it is not working well...iperf3 only 10Mbps
But I compile 19.07.4 directly from openwrt source code, mt76 works well, 58Mbps even good than MTK driver, weird, it should be same code.
Connecting to host 192.168.1.1, port 5201
[ 5] local 192.168.1.231 port 60966 connected to 192.168.1.1 port 5201
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.00 sec 7.43 MBytes 62.3 Mbits/sec
[ 5] 1.00-2.00 sec 6.83 MBytes 57.3 Mbits/sec
[ 5] 2.00-3.00 sec 6.92 MBytes 58.1 Mbits/sec
[ 5] 3.00-4.00 sec 6.93 MBytes 58.1 Mbits/sec
[ 5] 4.00-5.00 sec 6.90 MBytes 57.9 Mbits/sec
[ 5] 5.00-6.00 sec 7.01 MBytes 58.8 Mbits/sec
[ 5] 6.00-7.00 sec 6.93 MBytes 58.1 Mbits/sec
[ 5] 7.00-8.00 sec 6.94 MBytes 58.2 Mbits/sec
[ 5] 8.00-9.00 sec 6.97 MBytes 58.5 Mbits/sec
[ 5] 9.00-10.00 sec 6.98 MBytes 58.5 Mbits/sec
[ 5] 0.00-10.00 sec 69.8 MBytes 58.6 Mbits/sec sender
[ 5] 0.00-10.07 sec 69.7 MBytes 58.1 Mbits/sec receiver
iperf Done.
Openwrt 19.07.3 build -- patch failure
- mernst
Re: Openwrt 19.07.3 build -- patch failure
I did not check whether the patch related to the performance is in, but I wanted to give some feedback on how to get the VoCore2 with 19.07.3 running.
1. Follow strictly the documentation on https://github.com/vonger/vocore2 for the first steps:
2. now apply ALL patches which are described:
3. now additional apply following patch which is not described!:
4. copy the configuration files for the kernel into the right directory
5. copy now finally the config file for the openwrt make process into the main directory
6. now it's important to execute one time
7. then execute simply
8. finally the executable is available in
git clone https://github.com/openwrt/openwrt.git
cd openwrt
git checkout v19.07.3
./scripts/feeds update -a
./scripts/feeds install -a
cd ./package
git clone https://github.com/vonger/vocore2.git
cd ..
mkdir ./package/kernel/mt76/patches
cp ./package/vocore2/openwrt.1907/0822-mt76-read-factory-eeprom.patch ./package/kernel/mt76/patches
patch -p1 < ./package/vocore2/openwrt.1907/vocore2-default-banner.patch
patch -p1 < ./package/vocore2/openwrt.1907/vocore2-default-enable-wireless.patch
patch -p1 < ./package/vocore2/openwrt.1907/vocore2-default-lan-address.patch
patch -p1 < ./package/vocore2/openwrt.1907/vocore2-default-password.patch
patch -p1 < ./package/vocore2/openwrt.1907/vocore2-fixmaster-sdcard.patch
patch -p1 < ./package/vocore2/openwrt.1907/vocore2-default-enable-sdcard.patch
cp ./package/vocore2/openwrt.1907/config-4.14 ./target/linux/ramips/mt76x8/
cp ./package/vocore2/openwrt.1907/.config .
make menuconfig
make
bin/targets/ramips/mt76x8/openwrt-ramips-mt76x8-vocore2-squashfs-sysupgrade.bin
Users browsing this forum: No registered users and 3 guests
