Add IO to Vocore2 Ultimate
Posted: Tue Oct 27, 2020 4:45 pm
I really like the nice little plastic box that the Vocore2 Ultimate comes in. But I needed some additional connections to it so I added a connector as shown in the attachment.
The pins connect to the Vocore2 at 4 pins next to each other of GND, 3.3V, GPIO37, GPIO38 which gives you 2 IO pins and power and ground. With this setup I first used the ground and GPIO37 to power an OPTO 22 Model 120D10 solid state relay for controlling AC lamps around my house. The addition of a web page shows status and allows editing of cron jobs for timed or manual control.
Then I got to looking at the SHT20 in Vonger's blog. I wrote the program below to bit bang the i2c interface. Works nice to show temperature and humidity.
#include "stdio.h"
#include "unistd.h"
#include "sys/ioctl.h"
#include "sys/mman.h"
#include "fcntl.h"
#include "time.h"
#define NULPTR ((unsigned long *)0)
#define I2C_DATA_LINE 37
#define I2C_CLOCK_LINE 38
#define I2C_DATA_IN 0
#define I2C_DATA_OUT 1
/* Set Bits 32 - 63 */
#define GPIO_DSET1 0x0634
/* Clear Bits 32 - 63 */
#define GPIO_DCLR1 0x0644
/* Value in/out Bits 32 - 63 */
#define GPIO_DATA1 0x0624
/* Direction Bits 32 - 63 */
#define GPIO_CTRL_1 0x0604
/* Data mask Bit 37 */
#define GPIO_DATA 0x00000020
/* CLK mask Bit 38 */
#define GPIO_CLK 0x00000040
#define MAX_BUF 64
#define PAGE_SIZE 4096
#define MEM_BASE 0x10000000
#define SYSFS_GPIO_DIR "/sys/class/gpio"
unsigned long *mem = NULPTR;
/* vocore */
* mmap_page returns pointer to memory
unsigned long *mmap_page(void)
signed long fd = -1;
unsigned long *fmem = NULPTR;
fd = open("/dev/mem", O_RDWR);
if(fd < 0)
return NULL;
fmem = (unsigned long *)mmap(0, PAGE_SIZE, PROT_READ|PROT_WRITE, MAP_SHARED, fd, MEM_BASE);
close(fd);
return fmem;
/* vocore */
* gpio_set_dir
void gpio_set_dir(unsigned int gpio, unsigned int out_flag)
if(out_flag)
*((unsigned long *)(mem + (GPIO_CTRL_1 >> 2))) = GPIO_CLK | GPIO_DATA;
else
*((unsigned long *)(mem + (GPIO_CTRL_1 >> 2))) = GPIO_CLK;
/* vocore */
* gpio clear bits
void gpioclearbits(unsigned char data_pin)
if(data_pin == I2C_DATA_LINE)
*((unsigned long *)(mem + (GPIO_DCLR1 >> 2))) = GPIO_DATA;
else
*((unsigned long *)(mem + (GPIO_DCLR1 >> 2))) = GPIO_CLK;
/* vocore */
* gpio set bits
void gpiosetbits(unsigned char data_pin)
*((unsigned long *)(mem + (GPIO_DSET1 >> 2))) = GPIO_DATA;
else
*((unsigned long *)(mem + (GPIO_DSET1 >> 2))) = GPIO_CLK;
/* vocore */
* gpio get bit
int i2c_getbit(void)
if((*((unsigned long *)(mem + (GPIO_DATA1 >> 2))) & GPIO_DATA) == GPIO_DATA)
return(1);
return(0);
/* vocore reg */
* gpio set dir out
void i2c_clk_out(void)
gpio_set_dir(I2C_CLOCK_LINE, I2C_DATA_OUT);
/* vocore reg */
* gpio set dir out
void i2c_dir_out(void)
gpio_set_dir(I2C_DATA_LINE, I2C_DATA_OUT);
/* vocore reg */
* gpio set dir in
void i2c_dir_in(void)
gpio_set_dir(I2C_DATA_LINE, I2C_DATA_IN);
/* vocore reg */
* i2c data set state
void i2c_data(int state)
if(state == 1)
gpiosetbits(I2C_DATA_LINE);
else
gpioclearbits(I2C_DATA_LINE);
/* vocore reg */
* i2c clk set state
void i2c_clk(int state)
if(state == 1)
gpiosetbits(I2C_CLOCK_LINE);
else
gpioclearbits(I2C_CLOCK_LINE);
// Read a byte from I2C bus and send the ack sequence
// Put islast = 1 is this is the last byte to receive from the slave
unsigned char i2c_inbyte(int islast)
unsigned char value = 0;
int bitvalue;
int i;
i2c_dir_in();
for(i = 0; i < 8; i++)
usleep(100); // sleep for 0.2 milliseconds
bitvalue = i2c_getbit();
value |= bitvalue;
i2c_clk(1);
if(i < 7)
value <<= 1;
usleep(200); // sleep for 0.2 milliseconds
i2c_clk(0);
i2c_dir_out();
if(islast == 0)
// Send Ack if is not the last byte to read
i2c_data(0);
i2c_clk(1);
i2c_clk(0);
i2c_dir_in();
else
// Send Nack if is the last byte to read
i2c_data(1);
i2c_clk(1);
i2c_clk(0);
return value;
// Initializate the I2C bus
void i2c_init(void)
mem = mmap_page();
if(mem == NULL)
printf("can not map memory.\n");
return;
i2c_dir_out();
i2c_clk(1);
i2c_data(1);
// Send a start sequence to I2C bus
// Data goes low before Clock
void i2c_start(void)
i2c_data(0);
i2c_clk(0);
// Send a stop sequence to I2C bus
// Data goes high after Clock
void i2c_stop(void)
i2c_clk(1);
i2c_data(1);
// Send a byte to the I2C bus and return the ack sequence from slave
// rtc
// 0 = Nack, 1=Ack
int i2c_outbyte(unsigned char x)
int i;
int ack;
if(x & 0x80)
i2c_data(1);
else
i2c_data(0);
i2c_clk(1);
i2c_clk(0);
x <<= 1;
i2c_dir_in();
i2c_clk(1);
ack = i2c_getbit();
i2c_clk(0);
i2c_dir_out();
i2c_data(0);
if(ack == 0)
return 1;
else
return 0;
int main(void)
int loop_count;
int i2c_slave;
int RH, Temp;
unsigned char RH_hi, RH_lo, T_hi, T_lo, crc;
float RH_float, Temp_float;
printf("Temperature/Humidity ver 3.3\n");
i2c_init();
// SHT20
// | 1 | 0 | 0 | 0 || 0 | 0 | 0 | R/W |
i2c_slave = 0x80;
i2c_start();
if(i2c_outbyte(i2c_slave | 0) == 0)
printf("NACK received %d\n", __LINE__);
i2c_stop();
return -1;
if(i2c_outbyte(0xF5) == 0) /* Read Humidity */
i2c_stop();
return -1;
usleep(5); // sleep for 5 useconds
i2c_stop();
loop_count = 0;
do /* Wait for Ack during measurement */
i2c_start();
if(i2c_outbyte(i2c_slave | 1) == 0)
i2c_stop();
printf("Meas NACK received %d\n", __LINE__);
else
break;
loop_count++;
} while(loop_count < 10000000);
RH_hi = i2c_inbyte(0);
RH_lo = i2c_inbyte(0);
crc = i2c_inbyte(1);
RH = (((unsigned int)(RH_hi)) << 8) + RH_lo;
RH = RH & 0xFFFC;
RH_float = RH;
RH_float = RH_float / 65536U;
RH_float = RH_float * 125.0f;
RH_float = RH_float - 6.0f;
i2c_stop();
// Show the humidity level
printf("Humidity = %6.2f %% (0x%02X 0x%02X)\n", RH_float, RH_hi, RH_lo);
i2c_start();
i2c_stop();
return -1;
if(i2c_outbyte(0xF3) == 0) /* Read Temperature */
i2c_stop();
return -1;
i2c_stop();
loop_count = 0;
i2c_start();
i2c_stop();
else
break;
loop_count++;
}while(loop_count < 10000000);
T_hi = i2c_inbyte(0);
T_lo = i2c_inbyte(0);
Temp = (((unsigned int)(T_hi)) << 8) + T_lo;
Temp = Temp & 0xFFFC;
Temp_float = Temp;
Temp_float = Temp_float / 65536U;
Temp_float = Temp_float * 175.72f;
Temp_float = Temp_float - 46.85f;
Temp_float = (((Temp_float + 40.0f) * 9U) / 5U) - 40U;
i2c_stop();
printf("Temperature = %6.2f deg. F (0x%02X 0x%02X)\n\n", Temp_float, T_hi, T_lo);
return 0;
#include "stdio.h"
#include "unistd.h"
#include "fcntl.h"
#include "time.h"
#define MAX_BUF 64
/* vocore */
if(fd < 0)
return NULL;
close(fd);
return fmem;
/* vocore */
* gpio_set_dir
if(out_flag)
else
/* vocore */
* gpio clear bits
else
/* vocore */
* gpio set bits
else
/* vocore */
* gpio get bit
return(1);
return(0);
/* vocore reg */
* gpio set dir out
/* vocore reg */
* gpio set dir out
/* vocore reg */
* gpio set dir in
/* vocore reg */
if(state == 1)
else
/* vocore reg */
* i2c clk set state
if(state == 1)
else
int bitvalue;
int i;
i2c_dir_in();
value |= bitvalue;
i2c_clk(1);
if(i < 7)
value <<= 1;
i2c_clk(0);
i2c_dir_out();
if(islast == 0)
i2c_data(0);
i2c_clk(1);
i2c_clk(0);
i2c_dir_in();
else
i2c_data(1);
i2c_clk(1);
i2c_clk(0);
return value;
void i2c_init(void)
mem = mmap_page();
if(mem == NULL)
return;
i2c_dir_out();
i2c_clk(1);
i2c_data(1);
i2c_data(0);
i2c_clk(0);
void i2c_stop(void)
i2c_clk(1);
i2c_data(1);
// rtc
// 0 = Nack, 1=Ack
int i;
int ack;
if(x & 0x80)
i2c_data(1);
else
i2c_data(0);
i2c_clk(1);
i2c_clk(0);
x <<= 1;
i2c_dir_in();
i2c_clk(1);
ack = i2c_getbit();
i2c_clk(0);
i2c_dir_out();
i2c_data(0);
if(ack == 0)
return 1;
else
return 0;
int main(void)
int loop_count;
int i2c_slave;
int RH, Temp;
i2c_init();
// SHT20
i2c_slave = 0x80;
i2c_start();
i2c_stop();
return -1;
i2c_stop();
return -1;
i2c_stop();
loop_count = 0;
i2c_start();
i2c_stop();
else
break;
loop_count++;
RH = RH & 0xFFFC;
RH_float = RH;
i2c_stop();
i2c_start();
i2c_stop();
return -1;
i2c_stop();
return -1;
i2c_stop();
loop_count = 0;
i2c_start();
i2c_stop();
else
break;
loop_count++;
Temp_float = Temp;
i2c_stop();
return 0;
