Getting started
BryanBarbosa
Getting started
Fri May 14, 2021 2:48 am
Hello, VoCore-Friends!
I am just starting with VoCore2 and I don't know nothing about how to use. My goal is to control two stepper motors using the VoCore, but I can't not even understand how a simple "blink led" works. Could someone please help me with some tutorials for getting started?
I will be forever grateful!
Re: Getting started
Sun May 16, 2021 2:46 pm
You can connect LED + pin to any GPIO like GPIO38 and LED - pin to any GND.
call this to export GPIO38
echo 38 > /sys/class/gpio/export
call this to set GPIO38 to output mode
echo out > /sys/class/gpio/gpio38/direction
call this to set GPIO38 value, 1 to turn on LED, 0 to turn off LED.
echo 1 > /sys/class/gpio/gpio38/value
echo 0 > /sys/class/gpio/gpio38/value
VoCore2 GPIO max output current is 8mA(3.3V), so it should be safe to drive most LED, or you can add a resistor to limit the current.
Step motor is just same, normally it will need two GPIO connect to step motor driver board and send the control signal.
BryanBarbosa
Re: Getting started
Fri Jun 25, 2021 7:44 pm
Hi! Thank you very much! Using your instructions I was able to control ports using the terminal, when accessing Vocore 2 by SSH.
I was wondering: is there a practical way to write code in Vocore 2 or send a code written in computer to Vocore 2?
Re: Getting started
Tue Jun 29, 2021 1:03 pm
I am not sure I understand correctly :)
You can learn shell script to directly code on VoCore2.
Users browsing this forum: No registered users and 95 guests
