Disabling Ethernet subsystem on OpenWRT VoCore2
ofir
Sat Nov 20, 2021 10:43 am
I would like to be able to disable Ethernet at the hardware level.
I think it might be possible to turn off the clock for the Ethernet but I'm not sure how.
Chin Wei was kind enough to point out that rt3050-esw is the ethernet driver but grepping didn't yield anything useful.
Any idea how to disable the Ethernet subsystem through either "mem" utility or sysfs or at the driver level?
ofir@localhost:~/openwrt$ grep -Eir "clock|clk" --include='*3050*'
target/linux/ramips/dts/rt3050.dtsi:    clkctrl: clkctrl {
target/linux/ramips/dts/rt3050.dtsi:            compatible = "ralink,rt2880-clock";
target/linux/ramips/dts/rt3050.dtsi:            #clock-cells = <1>;
target/linux/ramips/dts/rt3050.dtsi:            clocks = <&clkctrl 18>;
target/linux/ramips/dts/rt3050.dtsi:            clock-names = "host";
target/linux/ramips/files-4.14/drivers/net/ethernet/mtk/soc_rt3050.c:           FE_FLAG_CALIBRATE_CLK | FE_FLAG_HAS_SWITCH;
target/linux/ramips/files-4.14/drivers/net/ethernet/mtk/soc_rt3050.c:           ret = fe_set_clock_cycle(priv);
target/linux/ramips/files-4.14/drivers/net/ethernet/mtk/esw_rt3050.c:   /* ext phy base addr 31, enable port 5 polling, rx/tx clock skew 1,
Thanks,
Ofir
Users browsing this forum: Bing [Bot] and 30 guests
