I have 3 vocores configured for ethernet, (eth0.1), different ips and mac addresses. Everything else (wifi, WAN, DHCP...) is off. I don't need anything else other than ethernet, no firewall, nothing.
If I connect them to a decent router all works great. If I connect them to a worse router I have intermittent comms. If I connect them to an unmanaged switch I also get intermittent comms.
Could there be anything wrong on the configuration of my Vocores that could be causing network issues, and that a good router could be solving?
My /etc/config/network file looks like this (different ips and mac addresses for eth0.1 for the other 2 units):
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fdf2:ba54:6f40::/48'
config interface 'lan'
option ifname 'eth0.1'
option ipaddr '192.168.0.207'
option ip6assign '60'
option gateway '192.168.0.1'
option broadcast '192.168.0.255'
option delegate '0'
option force_link '0'
config device 'lan_dev'
option name 'eth0.1'
option macaddr 'b8:d8:12:62:ae:cf'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '0 6t'
Both in the bad router and in the unmanaged switch I get this in one of the vocores, another doesn't even respond and the last one seems more or less ok.
44.793709] rt3050-esw 10110000.esw: link changed 0x00
[ 46.431885] rt3050-esw 10110000.esw: link changed 0x01
[ 48.386907] rt3050-esw 10110000.esw: link changed 0x00
[ 50.020357] rt3050-esw 10110000.esw: link changed 0x01
[ 50.223384] rt3050-esw 10110000.esw: link changed 0x00
[ 51.865861] rt3050-esw 10110000.esw: link changed 0x01
[ 57.735428] rt3050-esw 10110000.esw: link changed 0x00
[ 59.386378] rt3050-esw 10110000.esw: link changed 0x01
[ 64.469765] rt3050-esw 10110000.esw: link changed 0x00
[ 66.125834] rt3050-esw 10110000.esw: link changed 0x01
[ 68.269781] rt3050-esw 10110000.esw: link changed 0x00
[ 70.084105] rt3050-esw 10110000.esw: link changed 0x01
[ 74.151474] rt3050-esw 10110000.esw: link changed 0x00
[ 75.974147] rt3050-esw 10110000.esw: link changed 0x01
[ 77.869534] rt3050-esw 10110000.esw: link changed 0x00
[ 79.547146] rt3050-esw 10110000.esw: link changed 0x01
[ 83.809518] rt3050-esw 10110000.esw: link changed 0x00
[ 85.639175] rt3050-esw 10110000.esw: link changed 0x01
[ 87.410567] rt3050-esw 10110000.esw: link changed 0x00
[ 89.190917] rt3050-esw 10110000.esw: link changed 0x01
[ 92.270935] rt3050-esw 10110000.esw: link changed 0x00
[ 93.927710] rt3050-esw 10110000.esw: link changed 0x01
[ 98.282039] rt3050-esw 10110000.esw: link changed 0x00
[ 99.930628] rt3050-esw 10110000.esw: link changed 0x01
[ 104.310359] rt3050-esw 10110000.esw: link changed 0x00
[ 106.061059] rt3050-esw 10110000.esw: link changed 0x01
[ 108.050576] rt3050-esw 10110000.esw: link changed 0x00
[ 109.660932] rt3050-esw 10110000.esw: link changed 0x01
[ 111.730578] rt3050-esw 10110000.esw: link changed 0x00
[ 113.535235] rt3050-esw 10110000.esw: link changed 0x01
[ 117.730341] rt3050-esw 10110000.esw: link changed 0x00
[ 119.397640] rt3050-esw 10110000.esw: link changed 0x01
[ 121.410111] rt3050-esw 10110000.esw: link changed 0x00
[ 123.198724] rt3050-esw 10110000.esw: link changed 0x01
[ 123.879925] rt3050-esw 10110000.esw: link changed 0x00
[ 125.558020] rt3050-esw 10110000.esw: link changed 0x01
[ 127.429399] rt3050-esw 10110000.esw: link changed 0x00
[ 131.656452] rt3050-esw 10110000.esw: link changed 0x01
[ 134.709033] rt3050-esw 10110000.esw: link changed 0x00
[ 136.372484] rt3050-esw 10110000.esw: link changed 0x01
[ 138.589530] rt3050-esw 10110000.esw: link changed 0x00
[ 140.194307] rt3050-esw 10110000.esw: link changed 0x01
[ 140.991273] rt3050-esw 10110000.esw: link changed 0x00
[ 142.663698] rt3050-esw 10110000.esw: link changed 0x01
[ 143.269694] rt3050-esw 10110000.esw: link changed 0x00
[ 147.492099] rt3050-esw 10110000.esw: link changed 0x01
[ 149.410827] rt3050-esw 10110000.esw: link changed 0x00
[ 151.182595] rt3050-esw 10110000.esw: link changed 0x01
[ 154.209460] rt3050-esw 10110000.esw: link changed 0x00
[ 155.933955] rt3050-esw 10110000.esw: link changed 0x01
[ 156.671081] rt3050-esw 10110000.esw: link changed 0x00
[ 158.312963] rt3050-esw 10110000.esw: link changed 0x01
[ 159.010749] rt3050-esw 10110000.esw: link changed 0x00
[ 163.261955] rt3050-esw 10110000.esw: link changed 0x01
[ 168.549873] rt3050-esw 10110000.esw: link changed 0x00
[ 170.224131] rt3050-esw 10110000.esw: link changed 0x01
[ 171.011198] rt3050-esw 10110000.esw: link changed 0x00
[ 172.730115] rt3050-esw 10110000.esw: link changed 0x01
[ 175.814006] rt3050-esw 10110000.esw: link changed 0x00
[ 177.456387] rt3050-esw 10110000.esw: link changed 0x01
[ 183.011920] rt3050-esw 10110000.esw: link changed 0x00
[ 184.688642] rt3050-esw 10110000.esw: link changed 0x01
[ 186.550942] rt3050-esw 10110000.esw: link changed 0x00
[ 188.177666] rt3050-esw 10110000.esw: link changed 0x01
[ 193.751104] rt3050-esw 10110000.esw: link changed 0x00
[ 195.499010] rt3050-esw 10110000.esw: link changed 0x01
[ 197.430469] rt3050-esw 10110000.esw: link changed 0x00
[ 199.079938] rt3050-esw 10110000.esw: link changed 0x01
[ 201.110562] rt3050-esw 10110000.esw: link changed 0x00
[ 202.792198] rt3050-esw 10110000.esw: link changed 0x01
[ 206.031663] rt3050-esw 10110000.esw: link changed 0x00
[ 207.764226] rt3050-esw 10110000.esw: link changed 0x01
[ 209.509680] rt3050-esw 10110000.esw: link changed 0x00
[ 211.232257] rt3050-esw 10110000.esw: link changed 0x01
[ 221.511510] rt3050-esw 10110000.esw: link changed 0x00
[ 223.154178] rt3050-esw 10110000.esw: link changed 0x01
[ 229.909426] rt3050-esw 10110000.esw: link changed 0x00
[ 231.542531] rt3050-esw 10110000.esw: link changed 0x01
[ 235.910141] rt3050-esw 10110000.esw: link changed 0x00
[ 237.608193] rt3050-esw 10110000.esw: link changed 0x01
[ 241.909826] rt3050-esw 10110000.esw: link changed 0x00
[ 243.621121] rt3050-esw 10110000.esw: link changed 0x01
[ 249.253093] rt3050-esw 10110000.esw: link changed 0x00
[ 250.937601] rt3050-esw 10110000.esw: link changed 0x01
[ 256.512139] rt3050-esw 10110000.esw: link changed 0x00
[ 258.186497] rt3050-esw 10110000.esw: link changed 0x01
[ 265.989637] rt3050-esw 10110000.esw: link changed 0x00
[ 267.611905] rt3050-esw 10110000.esw: link changed 0x01
[ 272.050328] rt3050-esw 10110000.esw: link changed 0x00
[ 273.784065] rt3050-esw 10110000.esw: link changed 0x01
[ 276.851311] rt3050-esw 10110000.esw: link changed 0x00
[ 278.519041] rt3050-esw 10110000.esw: link changed 0x01
[ 282.850908] rt3050-esw 10110000.esw: link changed 0x00
[ 284.509185] rt3050-esw 10110000.esw: link changed 0x01
[ 286.530020] rt3050-esw 10110000.esw: link changed 0x00
[ 288.236545] rt3050-esw 10110000.esw: link changed 0x01
[ 294.932281] rt3050-esw 10110000.esw: link changed 0x00
[ 296.551425] rt3050-esw 10110000.esw: link changed 0x01
[ 300.869999] rt3050-esw 10110000.esw: link changed 0x00
[ 302.562303] rt3050-esw 10110000.esw: link changed 0x01
[ 304.470081] rt3050-esw 10110000.esw: link changed 0x00
[ 306.205953] rt3050-esw 10110000.esw: link changed 0x01
[ 308.232381] rt3050-esw 10110000.esw: link changed 0x00
[ 309.888768] rt3050-esw 10110000.esw: link changed 0x01
[ 316.632028] rt3050-esw 10110000.esw: link changed 0x00
[ 318.332160] rt3050-esw 10110000.esw: link changed 0x01
[ 320.293319] rt3050-esw 10110000.esw: link changed 0x00
[ 322.004740] rt3050-esw 10110000.esw: link changed 0x01
[ 327.429644] rt3050-esw 10110000.esw: link changed 0x00
[ 329.116415] rt3050-esw 10110000.esw: link changed 0x01
[ 333.509120] rt3050-esw 10110000.esw: link changed 0x00
[ 335.266050] rt3050-esw 10110000.esw: link changed 0x01
[ 335.908999] rt3050-esw 10110000.esw: link changed 0x00
[ 337.779967] rt3050-esw 10110000.esw: link changed 0x01
[ 343.250208] rt3050-esw 10110000.esw: link changed 0x00
[ 344.907008] rt3050-esw 10110000.esw: link changed 0x01
[ 350.389884] rt3050-esw 10110000.esw: link changed 0x00
[ 352.034558] rt3050-esw 10110000.esw: link changed 0x01
[ 363.589221] rt3050-esw 10110000.esw: link changed 0x00
[ 365.269759] rt3050-esw 10110000.esw: link changed 0x01
[ 386.390194] rt3050-esw 10110000.esw: link changed 0x00
[ 388.085759] rt3050-esw 10110000.esw: link changed 0x01
[ 390.069350] rt3050-esw 10110000.esw: link changed 0x00
[ 391.766271] rt3050-esw 10110000.esw: link changed 0x01
[ 400.931109] rt3050-esw 10110000.esw: link changed 0x00
[ 402.597631] rt3050-esw 10110000.esw: link changed 0x01
[ 404.472289] rt3050-esw 10110000.esw: link changed 0x00
[ 406.120705] rt3050-esw 10110000.esw: link changed 0x01
[ 409.269767] rt3050-esw 10110000.esw: link changed 0x00
[ 411.000062] rt3050-esw 10110000.esw: link changed 0x01
[ 418.870686] rt3050-esw 10110000.esw: link changed 0x00
[ 420.603389] rt3050-esw 10110000.esw: link changed 0x01
[ 424.930367] rt3050-esw 10110000.esw: link changed 0x00
[ 426.606334] rt3050-esw 10110000.esw: link changed 0x01
[ 452.592698] rt3050-esw 10110000.esw: link changed 0x00
[ 454.305790] rt3050-esw 10110000.esw: link changed 0x01
[ 476.592548] rt3050-esw 10110000.esw: link changed 0x00
[ 478.289150] rt3050-esw 10110000.esw: link changed 0x01
[ 532.871458] rt3050-esw 10110000.esw: link changed 0x00
[ 534.599688] rt3050-esw 10110000.esw: link changed 0x01
[ 554.469436] rt3050-esw 10110000.esw: link changed 0x00
[ 556.212220] rt3050-esw 10110000.esw: link changed 0x01
[ 568.999919] rt3050-esw 10110000.esw: link changed 0x00
[ 570.629372] rt3050-esw 10110000.esw: link changed 0x01
[ 587.074235] rt3050-esw 10110000.esw: link changed 0x00
[ 588.934139] rt3050-esw 10110000.esw: link changed 0x01
[ 597.751919] rt3050-esw 10110000.esw: link changed 0x00
[ 599.403894] rt3050-esw 10110000.esw: link changed 0x01
[ 649.688227] rt3050-esw 10110000.esw: link changed 0x00
[ 651.308539] rt3050-esw 10110000.esw: link changed 0x01
[ 651.777300] rt3050-esw 10110000.esw: link changed 0x00
[ 653.827579] rt3050-esw 10110000.esw: link changed 0x01
[ 655.590367] rt3050-esw 10110000.esw: link changed 0x00
[ 657.245691] rt3050-esw 10110000.esw: link changed 0x01
[ 657.608407] rt3050-esw 10110000.esw: link changed 0x00
[ 661.904635] rt3050-esw 10110000.esw: link changed 0x01
[ 664.833070] rt3050-esw 10110000.esw: link changed 0x00
[ 666.656251] rt3050-esw 10110000.esw: link changed 0x01
[ 667.136687] rt3050-esw 10110000.esw: link changed 0x00
[ 668.829179] rt3050-esw 10110000.esw: link changed 0x01
[ 669.280610] rt3050-esw 10110000.esw: link changed 0x00
[ 671.083514] rt3050-esw 10110000.esw: link changed 0x01
[ 671.552645] rt3050-esw 10110000.esw: link changed 0x00
[ 673.201659] rt3050-esw 10110000.esw: link changed 0x01
[ 691.472310] rt3050-esw 10110000.esw: link changed 0x00
[ 693.330685] rt3050-esw 10110000.esw: link changed 0x01
[ 884.151848] rt3050-esw 10110000.esw: link changed 0x00
Help! Multiple VocoreV2 same local network
- Chourizo
Re: Help! Multiple VocoreV2 same local network
The config looks no problem. It is very likely the ethernet cable problem or VoCore2 ethernet not physical well connected.
Users browsing this forum: No registered users and 101 guests
